P0403 (EGR Circuit Malfunction) & P0170 (Fuel Trim Malfunction) Airtrek
Ss_Tuner
Oct 20, 2015
16
7
www.facebook.com
Just sharing incase of any airtrekker have this issue.
Mostly have P0170 issues
Possible cause
1)EGR solenoid Removed
2)EGR setting disable/enable via periphery
Possible Solution : Disable via ECUFLASH
Possible cause
1)O2 sensor
2)Injector Scaling not correct.
3)Fuel Pump/Fuel Pressure Regulator setting not correct/weak
4)Too lean or rich idling/cruising.
Possible Solutions :
Check Fuelpump/fuelpressure at optimum level 3~4bar idle(vacuum off)
Rescale Injector Scaling STFT to be +/- 10% only
Check O2 sensor reading,change/clean(with wire brush) if no reading 0.1~0.9V please change.
https://www.facebook.com/SSEngineeringtuning
A brochure for the Japan-spec Mitsubishi Evolution X has leaked online revealing the final styling of the new car’s exterior and cabin as well as its power and torque figures...
