Nissan GT-R
sakuraguy
5,000 RPM
5,834
27
Sendai, JAPAN.
www.zerotohundred.com
Best Car magazine in Japan is showing off a couple of pictures of the upcoming GT-R and reporting some interesting stuff. They claim:
"The standard GTR is expected to start at $57K while the V Spec and EVO Spec will start at $67K and $94K respectivly. Both a 6 speed and an advanced paddle shifting automatic are to be available. The Standard GTR and Spec V will be equiped with a 480HP version of the VQHRTT engine(displacement is either 3.7 or 3.8L as it has not yet been confirmed).
The GTR EVO will receive a 530HP version of the VQHRTT engine as well as being roughly 220lbs lighter then the standard GTR, coming with light weight seats, a larger more aerodynamic rear spoiler, large ceramic brake rotors, and a revised Altessa AWD geared for more track use."
However, I tend to not takes these news and images from Japanese magazines very seriously. They aren't usually very accurate at all. Click on the images for larger picture.
imoloq
1,069
25
1,648
Advanced paddle-shifting automatic? Hope it's not as bad as the one in auto GTTs.
Carb0n
14
what is the torque like? around 800Nm? zth at 3.7 sec, that is mad.
Alchemis
1,416
47
1,648
the power of 280 ps is already lifted about a year ago...
no more 280 gentlemen agreement...
cb70
262
Serdang
The engine is v6 not straight 6? Straight 6 is more powerful than v6 rite in terms of torque?
si|verfish
5,000 RPM
5,797
PJ
Erm...I don't think there is any definite rule which states that a straight 6 has naturally more torque than a V6.
The benefits on a straight 6 is that it is naturally balanced and is simpler than a V configuration 6. The downside is that it is long and that's where the V6 comes in being more compact but has the drawback of being more complex.
The Marketplace Top Posts
Guys, I have some problem, after some investigations:
- usually when temperature passes half, radiator fan will on and once the temp is slightly below half, it stops
- problem is, sometimes even after half, the fan is still not moving causing the temperature raised high (almost red bar)
- i thought the fan broken, tried to knock the motor (suggestion from a friend), still not working
- but, when I turn the AC on, both fans (radiator & AC) are on now. Meaning, my radiator fan is working! It...
