Re: NGV Untuk Kereta Engin Turbo
okie, its a good question, so i beg admin not to delete this post.
u can charge any ngv equipped vehicle safely, but boost has to be limited. the thing is, i dont think the ngv pump is able to pump enough gas up if u boost it higher. if u can get a higher capacity pump, maybe u'll be able to fuel up accordingly at higher boost, but for now, the pump isnt sufficient imo. decreasing the compression will help to make the engine more reliable, and cooling system may need an upgrade to make sure the temperature stays cool on long journeys/operations.
i have a fren dat feeds ngv gas to his kancil turbo drag setup, and was able to gain high horses at high boost application. dont get me wrong, dis is a drag car, dat applies max power at most 14sec, so it may lasts longer den street vehicles. this shows dat u can have similar result nonetheless, if everything else is set accordingly. tq sir
