ngk or ultra cable plug
Exactly! Thats why I dont belive on buying spark plug cables first, but as they say... to each his own :rolleyes:
hmmm, how big/strong the spark depends on your spark plug and not to mention your coil as well. If your coil can't produce enough voltage to ignite the plugs, what's the use if u change to a super-expensive-high-performance plug cable? this is just my layman's theory, not sure whether it's true or not... don't shoot me :rolleyes:
bigger sparks = better combustion = more hp but i don't think u can feel it at all the hp u gained. maybe u can notice in dyno charts but obviously not when u are driving it. some engines will respond or idle better because of a more stable electricity flow, i think.
yes... 1st, having a decent ignition coil + decent plug cable = better result.
Stock ignition coil + decent plug cable = will only feel a bit better in respond only.
2nd... decent plug cable, and stock plug cable also can idle better... It still depend on how better the condition of you cable itself, and even many factor too.
---------- Post added at 05:54 PM ---------- 6 hour anti-bump limit - Previous post was at 05:51 PM ----------
Actually, most of the branded after market maker claim that their plug cable can deliver stronger spark at the spark plug compare to stock's. They can even show it on their demo. However, does it improve hp? Theorithically, yes. Practically... some was able confirm it by dyno chart which is, only very very small increase in %. If your are running a high hp engine, small % can become a 5hp. But if you are running SVT/BT, then small % can be "ignoring figure" from sciencetific calculation point of view :biggrin::biggrin:
I believe the respond graph would slightly change. But improvement in HP, maybe as you said "ignoring figure"
that is Nology la...
Nology is under Sun Auto le....
---------- Post added at 09:24 AM ---------- 6 hour anti-bump limit - Previous post was at 09:16 AM ----------
aiyo.. said until no value of aftermarket plug cable...
There have some increasing and use too man or else they will never develop such an useless item la... But increasing won't be that much also.:rofl:
i'm using this 1...
if ngk vs ultra, i choose ngk...
ultra have red in color n blue in color..blue color better than red..if i not mistaken laaa
i'm using this 1...
No ideal already... but it exactly same design with Nology and same using Sun Auto company too...
---------- Post added at 11:13 AM ---------- 6 hour anti-bump limit - Previous post was at 11:10 AM ----------
It still need see the diameter too, can't measurement with color code le.
