Need Help: EK9 Front & Rear Bumper Beam
Venzonic
Dear All Sifu (especially Jin, Hikaru & Sasuke, i know u guys did it):
I got the EK9 Fr. & Rr. Bumper Beam wanna installed on EJ6. I have read some of ur guys post on the installation (Plug & Play)...However, I found out that it is not so direct plug & play, hence I need some advice from sifus in more detail. Please kindly refer to the attachment for more details....
All sifus please kindly advice me.....pls....pls...thanks a lot....:vollkommenauf:
[Sorry, I don't know how to put picture here;so need to use attachment n many restriction on file type for attachment,so i need to use zip file,sorry...!!]
The front is P&P, rear will need very minimal mod which can be resolved by common senese.
Thanks Hikaru sensei, so the front will use back the existing mounting point (Hole 1 & 2, no additional drilling). Am I right?
The rear need to knock out/ remove the metal plate with hammer & chisel, then mount to the existing hole with bolt & washer. Am I right?
Please kindly advice.
I know there are many ways to get the job done, however I just want to do it correctly without doing unnecessary modification to the chassis. Or as close to the designed mounting instruction as possible.
Hence, please kindly teach me the correct way. Some photos will be nice if not too troublesome to u.
Thanks a lot for your help in advance n pls.....
:hmpf:No one can help me here ah......aiyo....pity myself....
