MTX RT-X01A 2-way electronic crossover
The RT-X01A is a nice,2-way crossover with fully adjustable x-over points from 32hz to 400hz for both hi- and lo-pass.
Another nice feature is fully adjustable gains for both outputs.
This crossover also accepts hi-level inputs, so you could hook it up to your factory stereo outputs and use it as a crossover/line level converter to run aftermarket amps and speakers from.
Specs
Two Continuously Adj. High & Low Pass Crossover Points
Gold Plated RCA and Screw Terminals
Two Continuously Adjustable Output Gain Controls
12dB/Octave Crossover Slopes
Four Gang Potentiometers
Low & High Level Inputs
96dB Signal-to-Noise Ratio
THD Less Than .05%
Variable Crossover Frequencies from 32Hz to 400Hz
DC to DC Power Supply
Sorry, No returns on vintage electronics.
---------- Post added at 02:34 PM ---------- 6 hour anti-bump limit - Previous post was at 02:33 PM ----------
.bump.
