Mitsubishi Turbo specifications.
absolut250 said:
hi,
i want to know how much difference will it be when i upgrade my nissan t25 to a garret t28 ball bearing turbo. boosting at 0.5 bar.
currenty the turbo spool at 2krpm and the kick comes in at about 4.5krpm. will the upgrade allows me to spool up at a lower or same rpm and the kick will come faster and stronger?
sorry fr crossing, I need an info here.
what nissan model do use this t25 as stock, I might seek the h cut for that turbin, or just mention garret t25 then the TAUKE may no which is garret t25.
I found t28 B/B from sylvia S15, but they qoute me RM 1200. May I have its next time.
TD 04H normally can be found on stock mitsu GSR 1.8t right???
Then TD 04L info I hered it stock for subaru IMPREZA, then from what impreza model.
thank all turbin GURUS here :rock:
TD04 can be found in many turbo cars such as Mitsubishi GSR, Volvo T5, Volvo S40and all Subaru WRX models(non-STi)
hi all ...
need help..
i think my turbo is start leaking and my car has white smoke on boost...
i`m using old car with mitsu E3 engine...
my engine is standart, i want to changed my turbin...
need opinion from turbin sifu, what kind of turbo that much better from E3 turbo?
ok well... evo 3 is a TD05H-16g6-7... any turbo from an evo 4 onwards would be much better... the turbine housing size for you turbo is quite small compared with the later models.... for comparison.. look at the chart above,,,, anyways.. I am selling a TD05HR-16G6-9.8T from my evo 7... I just changed my turbo. It is in good condition and it just came out from the car a few days ago... its not a second hand unit!!.. I made a post in the selll performance part section.. private owner.. if anyone interested... message me!
i think i may need bbearing turbo...just want some info,bbearing turbo which better from e3 TDo5H,how much u want to sell urs andyc?
titanium turbine
hi to all turbo sifu's..
how to differentiate a mitsu titanium turbine? wat model #?
from wat i see, every mitsubishi titanium-alloy turbine model # read as TD05HRA (EVO 6/7/8/9 RS, 6 TME, 8 MR) n mitsubishi inconel (steel alloy) turbine model # read as TD05HR (EVO GSR), so the different between both turbine model # is the 'A'. So does it mean the 'A' tells the turbo with titanium turbine?????
thx.
brother i have some question. what gear box can i use for my eterna twin turbo?? my ride using auto. i wan to convert to manual. what gear box can i use except the eterna gear box?? can i use mivec v6 gear box?? thanks
i have a TD06-17C but it comes with non wastegate turbine housing. after search through some website, i found that all TD06-17C comes with internal waste gate.
here are the photos
any one have idea where this housing comes from? currently i have problem as i don't have any boost built from this combo on my 1.8L engine. my HKS wastegate has been tune to the hardest spring pressure but still no boost even i revv till 5000RPM.
to all Si-fu, help me please..
sifus, i need to know the differences between TD05H 16G (evo3) and IHI RHF5 VF23... which 1 is bigger n hv more advantages?
hope u guys share infos... thanx
hi everyone!
i got a query for the mitsubishi colt version r recaro edition.
which is a mivec turbo-charged 4g15,with 150hp on crank.
i just want to know,what is the turbine for this car?
FYI,this car do not sell in Malaysia,i saw it at Singapore.my bro-in-law is interested with this.
any info about A/R 70 Ball Bearing 25G?
GSR stock engine can support?
need advise from all sifu here.
Tq. ;-)
