misfire
stutzedward
3,416
561
maybe ... but I was taught not to rev the car hard when it's cold. Learnt it from the days when I first owned a car - 78 Colt Mirage. You know carb cars are like that... and its like nto warming up ourselves before doing some hardcore exercise... will hurt ourself too...
Not hard revs loh! but step slightly on the accelerator to increase the idling speed.....:driver:
4gbanger
1,958
386
1,683
Johor/ShahAlam
you need more time to check at this problem.. cause it wont always a big issue to solved. sometime it was just a loose MAF socket like my friends did last time. take your time to check one by one.
Yah! my mechanic did before on one car. Remove all sockets he can find, spray contact cleaner then put back.....:driver:
stutzedward
3,416
561
It's a good exercise to remove contact sockets, spray with contact cleaner to improve electric signal connectivity.
mdss
71
9
508
uk
I cannot find anything I have tried to spray contact cleaner into the connectors but still no joy. I have not cleaned the throttle body so maybe I will give that a go. The only thing left is to replace the battery, a good friend had a Porsche boxster that would do the exact same thing when cold after being first turned on and then it would clear. It turned out to be the battery.
This is very very frustrating. My tuner has a MUT tester so I am hoping it does it in the next few days so I can drive the car over and hopefully it has logged a fault. Like I said some days its perfect and others it does it straight away.
Thanks for all the help its much appreciated.
Hi guys thanks for all the replies. The problem still persists!
I have tried the other coils from my evo that did not work.
I have put on another maf and again this has not worked.
I am now going to try and replace the injector pack as I have a spare somewhere.
Its very odd as it only happens as soon as you turn the car on, once you press the accelerator hard it clears and is fine, more odd is that it does not do it everyday, there seems to be no pattern to this odd behaviour.
Can anyone think what else it could be? As I said its fine on full throttle no misfires but on the first few presses of the throttle when cold it misfires then clears.
I am becoming very frustrated with it to be honest as the car is great and was hoping to keep her for at least another 2 years.
Any help is always appreciated.
I know nothing about Airtreks. However I've had this problem with my wira before. Turned out to be my spark plug cables. Does the Airtrek use cables? Or COP? if COP perhaps you have one that's breaking down soon?
Not sure if diagnostic will show anything if there is no check light coming on.
Yah! the battery thing you mentioned can be also. My VR got one time idle poorly, however car can still start but can hear having weaker crank, so did not think of changing the battery. However later I decided to change the battery in case it died on me, and like you mentioned the poor idling disappeared....:driver:
stutzedward
3,416
561
Atr has 2 COP and 2 cables... so the coils are shared.
4gbanger
1,958
386
1,683
Johor/ShahAlam
better find someone with the same car and runs well.. so you can swap test the parts one by one till you found which one is the error. we'll do exactly like that here..
That is why having friends and joining car club has it's advantages......lol
Last time my mechanic had one new customer came, say he went to other mechanics and they have changed the plugs, plug cable, distributor, almost everything to do with the ignition system but still jerks. The car was a 3 door first Gen Accord and at that time back in early 80's already running electronic. So he called me whether I can pop over with my car, he swap that unit and the car starting running fine, so that customer was so relief, but he already changed so many things.....lol
I need help adjusting this carburetor..
anybody know how i can tune this thing?
my engine idle RPM too high..about 1.7k RPM..
where to find its idle screw and mixture screw?
