hex999
NEW MICHELIN PRIMACY 3 tires (Year 2016) x4
Car recently repainted with GLASURIT base paint (Gold)
Interior refurbish (50% refurbish)
Catalytic converter replacement X 2(Done at jian hang)
Full car 3M original TINT with warranty (All mirrors)
NEW YOKOHAMA DIN100L MF BATTERY
NEW BOSCH GERMANY DISC ROTOR x4
NEW GERMANY BRAKE PAD SET x4
Brand new fully functioning side mirrors with flip X 2
NEW LOWER ARM ORIGINAL (GERMANY) x2
NEW WATER PUMP
FULL FLUSHING (radiator coolant, brake oil, power steering oil)
NEW IDLE ARM ORIGINAL x2
NEW RH UPPER ARM ORIGINAL x2
NEW UPPER HOSE
NEW LOWER HOSE
NEW WATER PUMP HOSE
NEW WATER JACKET 34MM
NEW 16MM WATER HOSE
NEW ORIGINAL THERMOSTAT
NEW THERMOSTAT HOUSING
NEW THERMOSTAT SENSOR
NEW FRONT RH DOOR VACUUM PUMP
NEW FRONT LH DORR VACUUM PUMP
NEW FRONT RH DOOR VACUUM PUMP ROD
NEW CENTRAL LOCKING VACUUM RELAY
NEW ALARM TAMARAK
NEW FAN BELT TENSIONER PULLY
NEW ORIGINAL AIRCOND COMPRESSOR
NEW EXPANSION VALVE
NEW RECEIVER DRIER NEW CONDENSER 5' JAPAN HOSE CONDENSER
NEW FAN BELT 6PK 2225
Many more not listed!
At least RM20K++ worth refurbishment has been done on the car this year (2016) alone. The car has been taken care well and the reason why it was done up on the first place was for the owner’s daughter’s wedding because she insisted on this car. After the wedding, no one is using the car. Now since the car is parked stationary and it’s not being used, the owner has decided to sell this car and let another car enthusiast take care of it.
NEW WATER PUMP
NEW UPPER HOSE
NEW LOWER HOSE
NEW WATER PUMP HOSE
NEW 16MM WATER HOSE
NEW ALARM TAMARAK
NEW EXPANSION VALVE
