Kyosho 1:28 scale ASC collection.
supersos
23
3,003
finally , my AE86 ready for drift after deco lighting & setting up with correct solid axle , Ball diff lock . It awesome while drifting this machine.....to be cont....
supersos
23
3,003
Touring body Shell Honda HSV ARTA Super GT and Old School Nissan Nismo Z 2005 Test Car
supersos
23
3,003
Kyosho Audi LMS R8 Red with MR03 Kit + Atomic Front I.S.A arm , S.C.S center self adjust shock , Atomic Mid Motor Mount.
Kyosho Honda Hsv ARTA GT with Mr03 Kit + PN Front Double A-arm , Rear Kyosho Oil Shock, PN V3 Motor Mount (94/98mm)
Kyosho BMW M3 , With MR02 Kit + Pn Front Double A-arm , Rear Kyosho Oil Shock , PNMotor Mount (94mm)
TRP Megane Rally with AWD Kit 2.4ghz, Front PN Mount , Rear Atomic SAS V3.
Feel free drop by and have a try At Element Z.
supersos
23
3,003
350Z GT500 94mm custom airbrush paint job with water decal slide sticker.
Overall very easy handling bodyshell when play and with front rim offset +1 and rear +2.
supersos
23
3,003
Kyosho Mini Z Malaysia Season Race 2013 is here.
This year, we have Mini Z Dynasty and Mini Z Element cooperate to organice the event. Please don't miss it.
Grand Lucky Draw for racer who have attend 5 of 5 races. Let's get your race machine reeeeeeady!!!!!!
Rules And Regulations.
(Update July 2013)
Car Specification
Chassis
- Open to all 1/27 on road cars, i.e. Kyosho Mini Z AWD, MR02, MR015, MR01, Firelap, Iwaver and X-mod.
Body Shell
- Kyosho, TRP and Firelap Body shell are allowed.
- Pan Car and Lemans body are not allowed in both stock and modified class.
- Judges reserve the right to disqualify a body for excessive material removal.
- All windscreens must be remaining secure in the body shell.
- Lexan Body are not allowed
Motor
- PNWC Official 70 Turns Stock Motor for the 1st race.
- Atomic Standard Motor 60T
- 1st race all racer must run with PNWC 70T motor
- 2nd race until last race, A Main top 3 driver must remain on PNWC 70T motor, others racer can choose Atomic Standard Motor 60T or PNWC 70T motor to use.
- Silver and carbon brush allowed to change.
- Motor must run with original motor can, original magnet and original armature.
Wheel
- Unlimited.
PCB Board
- Only original Kyosho, Atomic, Firelap or X-mod PCB boards are allowed. FET upgrade is allowed. External Turbo is allowed.
Battery
- Car must be powered by four AAA size batteries. No more, No less.
- Batteries must be Alkaline, NiMH, or NiCd.
- No other type of battery is allowed. / For example: Lithium Polymer batteries are not allowed.
- Extra Capacitor is allowed.
Tyre
- Any Brand: Rubber/silicone tyre only.
- No foam tires allowed.
- No traction compounds allowed on tires, or race surface.
- Tire warmers are allowed / Tires only cleaned with a 70% alcohol solution.
WEIGHT, WIDTH & HEIGHT
- Minimum weight (170g)
- Max wheel base (98mm)
- Max car length (180mm)
- Max car width (80mm)
- Max car height with wings (45mm)
Transmitter
- Any brand transmitter.
Lap counting system
- Robitronic transponder system
- Race organizer will on the lap counting system 1 hour for testing. Driver are encourage to test and make sure the transponder is place in the correct matter.
- In our pass experience, miss lap is due to driver handle the transponder not correct. Miss lap is responsible by the racer.
- Race organizer final result is the final result.
Marshal
- Drivers are responsible and compulsory to be a marshal when the other groups or mains is in racing. For example A main drivers need to be B Main marshal when B main is racing or vice versa. Penalty will be imposed for drivers who fail to be a marshal.
Race Detail
Date
03-08-2013 Dynasty Saturday 8pm
31-08-2013 Dynasty Saturday 8pm
05-10-2013 Element Saturday 8pm
09-11-2013 Dynasty Saturday 8pm
14-12-2013 Element Saturday 8pm
Mains Grouping
- Main will be justified by the qualifying hits on the race day.
Registered
- Last date to register, please refer to the race calendar
Qualifying Hits
- 3 x 5 minutes qualifying time, starting grid position to determine by the qualifying hits.
- There will be three qualifying runs for each class.
- Each run will last 5 minutes.
- For the first run, the starting grid will be staggered in a random order.
- For the second run, the starting grid will be reversed.
- For the third run, racers will be re-shuffled into heats based results from the
previous two qualifier runs.
- The starting order for each run will be based on the number of laps run in
the time allowed.
Race Format
- A Main
3 x 10 minutes final.
- B and C Main
- 2 best final result will recorded at point system.
- Point system is according to following
1st 100p
2nd 99p
3rd 98p and so on
- If there is same point occur between drivers, driver who get the best result in the best 2 final will be the champion.
- Example:
Driver A best 2 results are 1st and 3rd. Total point is 198.
Driver B best 2 results are 2nd and 2nd. Total point is 198.
Driver A best lap is 52 laps 10.00.00 for 3 races
Driver B best result is 52 laps 10.01.000 for 3 races
- Champion goes to driver A because Driver A have the best result.
Fees
- RM50 per race including track fees.
- RM5 for transponder rental for who do not have personal transponder.
Result
- There will be 5 races in 5 months. The best 4 results will be chosen to calculate position.
Point System
1st - 25 point
2nd - 20 point
3rd - 16 point
4th - 13 point
5th - 11 point
6th - 10 point
7th - 9 point
8th - 8 point
9th - 7 point
10th - 6 point
11th - 5 point
12th - 4 point
13th - 3 point
14th - 2 point
15th - 1 point
Top qualifier (Qualifying A Main 1st)
1 point
Note:
Due to limited pit stop place in Mini Z Dynasty and Mini Z Element. Participants are encouraged to well organize the pit stop area.
Any loss, broken or stolen item are not responsible by Mini Z Dynasty and Mini Z Element.
Rules will be update from time to time.
Thanks
Organized by:
MINI Z DYNASTY
MINI Z ELEMENT
Sponsor by:
ATOMIC
PN RACING
Management reserves the right to change and update the rules and regulation without prior notice.
__________________
https://www.facebook.com/minizelement
Eat , Sleep , Play Mini Z.......
supersos
23
3,003
AUDI R8 LMS Limited Edition .
Supra_Fanatics
Beyond 20,000 RPM!
20,673
3,998
How much is 1 Mini Z?
supersos
23
3,003
hi Supra,
u got pm.
supersos
23
3,003
u got pm dieung.:wavey:
supersos
23
3,003
Honda HSV is back......
supersos
23
3,003
New Product Introduction:
Atomic AMZ 4WD scale 1:27, suitable use Kyosho ASC / White Body .
Package Included New Car Kit 1:27 made by Atomic RC.
The RTR Kit AMZ001-4WD is built on a carbon fiber main chassis with an upperdeck made from the same material.
The double wishbone suspension allows for droop, toe and camber adjustment and the shocks come grease-filled to achieve the maximum traction.
Included in the kit the designed platform of 7.4V Li-Po battery packs,
a 2.4GHz FHSS radio system and a micro stock brushless 5000KV speed controller made by Hobbywing.
Features
- Chassis compatible with Mini-Z A.S.C series
- Professional micro brushless speed control cooperation with world leading brand HobbyWing. (Support programming adjustment)
- VMX 5000kv BB brushless motor
- Front and rear double swing arm, for F/R droop, toe-in/out, camber…etc
- Front and rear ball diff. and universal drive included
- I.A.S. grease shock for easy to setup ride height and weight balance. Excellent (7) shock absorption
- Machine cut carbon fiber chassis and flex. upper deck
- 64 pitch gears, aplenty range gear ratios
- Li-po 2S 7.4V platform
- 2.4Ghz FHSS proportional 3Ch radio transmitter include
- Ready for Lexan body. (Optional item, not include in kit)
Code: AMZ001-4WD
Source: Atomic RC
We are ready indoor carpet track for racer enjoy together with member and enjoy the fun of Mini-z....
TitanRev
You think I print money?
Mar 3, 2005
8,180
3,678
PM me HSV price.. Thank you
to be or not to be?
Rotary polisher are best to be removed scratches, swirls and compounding marks left behind from the inexperienced (previous hacker) BUT also the worse in ruining one paint....it is highly recommended that rotary polishing should be only...
