currently i am a owner of a kenari, need some advice regarding the reapir for it.
my front right tire side hit a divider causing the rim to bent little bit and the car is out of alignment.
went to workshop for inspection and found out that the lower arm of the right tyre is bent. pulling the chassis mount bent a little bit as well. is it true that replacing the lower arm needs to replace the chassis mount that the lower arm is mounted on to.
according to the workshop/mudguard the engine needs to be overhaul in order to replace those part and cos RM1K+
now i'm little worried if i'm going to be conned. can anyone recommend me a real trustable workshop?
i'll post a picture here later to show the damage.
