3 unit high quality amplifier for sale:
1)Phoenix Gold Xenon 1200.1 monoblock amplifier (made in korea)
1200w rms output at 4,2,1 ohm(thd 1% 14.4v)
price:rm1300
2)Orion XTR 200 2ch dual mono high current amplifier (made in USA)
100W x 2ch @ 4ohm on 12V battery [rated]
200W x 2ch @ 2ohm on 12V battery [rated]
400W x 1ch @ 4ohm on 12V battery [rated]
726W x 1ch @ 1.15ohm on 12.5V battery [measured]
983W x 1ch @ 1.15ohm on 14.4V battery [measured]
THD: 0.005%
Slew Rate: >500 Volts per microseccond
Output Damping: >1000
S/N w/balanced input: 112dB
Power Bandwidth: 6Hz to 1000kHz +/- 5dB
Idle Current: 1A
Full Power: 28A @ 13.6V
price:sold
3)JBL Crown BPX 1100.1
RMS Power Rating:
4 ohms: 1141 watts x 1 chan.
1 ohm: 1022 watts x 1 chan.
Max power output: 1312 watts x 1 chan.
Current Servo Circuitry with Crown Technology
High-efficiency switching power supply
Wired remote bass level control included
LED I-E/OPT, power, and protection indicators
Tuned Bass EQ (adjustable bass boost)
Parallel/bridgeable operation
Preamp RCA outputs
Dynamic Bass Optimization (DBO) - This provides variable filtering with adjustable "Q" below 100Hz, far beyond conventional "Bass Q" circuits, by allowing the low-frequency output to be optimized for specific subwoofer applications
DC, thermal, voltage, overload, and short circuit protection
Die-Cast Aluminum Chassis with Top Plexiglas Viewing Window
Variable low-pass filter (32-320 Hz, selectable 12 or 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 21-320 Hz
Dimensions: 17"L x 12-1/4"W x 2-9/16"H
4-gauge power and ground leads recommended. Contact us for information regarding a discount on a select amplifier kit when purchased together.
price :rm1500
price:rm1300
THD: 0.005%
Idle Current: 1A
price:sold
RMS Power Rating:
Preamp RCA outputs
price :rm1500
