![LM2%20med.jpg](http://www.nzperformance.co.nz/store/images/uploads/New%20images/LM2%20med.jpg)
There's a brand new product from Innovate. It's called the LM-2. For the old price of a plain old wideband system, you now get a full OBD-II aware data logger, code scanner, and display system. The LM-2 plugs into your OBD-II port, so it can read, display, and log any of the information your ECU knows. Plus, it's a wideband air/fuel meter. Plus, it logs it all to an SD memory card, so you can upload the results to your PC for analysis.
The LM-2 combines an air/fuel ratio meter, a full-function 32-channel datalogger, and powerful software to deliver a complete tuning workshop for less than the cost of one dyno day. Whether you have a piggy-back fuel controller, race carb, aftermarket ECU, ODB-II tuning software, or a flash/chip programmer, an LM-2 is the tool you need to dial in maximum HP. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-2’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
- Patented “Direct Digital” Wideband Technology
- Wideband O2 Compatible with ALL fuel types
- Single or Dual Channel Version Available
- OBD-II Scan tool- read/clear DTCs and log up to 16 channels of CAN OBD-II Data
- Log directly to SD card (included)
- Playback log data on screen and/or with powerful LogWorks software (included)
- Large high-contrast graphics LCD
- Built-in RPM converter (direct frequency or with optional inductive clamp)
- 4 fully-differential analog inputs
- 2 configurable linear analog outputs
- Positive lock connectors for all connections
- Innovate MTS serial IN and OUT
- USB connection to your PC
The config screen:
![lm2screen.jpg](http://www.autojunctions.com/images/stories/lm2screen.jpg)
The LM-2 is available in two different kit configurations:
1) The LM-2 Kit (Single Wideband O2) includes the LM-2 meter, Bosch wide-band oxygen sensor, 8 ft sensor cable, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, weld-in bung and plug, LogWorks software CD, and quick-start guide.
2) The LM-2 Duo Kit (Dual Wideband O2) includes the LM-2 meter, (2) Bosch wide-band oxygen sensors, (2) 8 ft sensor cables, cigarette-lighter power adapter, analog in/out cable, ODB-II/CAN interface cable, SD memory card, USB cable for PC connection, (2) weld-in bung and plug kits, LogWorks software CD, and quick-start guide.
It's really a must have for all you DIY guys or for Workshop use!
So for those who runs stand alone engine management system and or tunes their own cars this Innovate LM2 is the ideal and perfect item to have. For further information, please call Yoo G at 012.2808.692
Item is priced COMPETITIVELY at RM 1928.00
for bulk purchases, price is negotiable.
