Hello friends :wavey:
When you care for something, you want only the best for it. My buddy is of that breed. He came to see me as he wanted me correct his ride, a sporty Honda Civic. We then set a tentative date. His brother brought the car 2 days in advance. I was not at home.
The ride was well taken care of overall although with the alternate sun and rain prevailing, you can’t expect cars to be dirt-free.
I started the next day. A close inspection of embedded dirt revealed these.
The boss gives a meticulous demonstration of the job with his detailing brush, a toothbrush and Surfex diluted.
It starts raining heavily.
Washing in a bubble!
Claying
The real benefit of using clay is actually trying it out!
These are from 3 sections of a well kept car. Without claying, it would have been impossible to see the bonded contaminants!
To the defects now:
Lacking definition and depth
Extreme close-up
The rear bumper
The vertical panels
Orange peel city, helped by silver color! Not easily noticeable
Deep Scratches
Closer look
Flake-offs
I’d be very much grateful to know if anyone among you performs these touch-up repairs without using the kit.
Space conquest!
Ladies and gentlemen, fasten your seat belts. We are going to land on the moon!
A whole side filled with moon craters and hills!
These need re-spray of course.
Surface prepping
Wetsanding using Megs sanding block and Mirka sandpaper - 1500, 2000, 2500 depending on the severity of defects
At this stage, the owner would be shocked/shocked seeing his car gone from bad to worst!
Final Wash n Clay
It’s taken me so many days to reach here! The paint was so uneven.
Ready for Fun
My friends
Makita 9227, Flex 3401 (I’ve started to love the Flex but this hasn’t decreased my love for the Makita)
Polishes: Optimum Hyper Compound, Menzerna ( PG (the ol’ one), 203S, and PO85rd)
Pads: Optimum Wool pad, Lake Country (FWP, White and Black)
Sealant: Menzerna Powerlock
Glass: Menz PG, DP Glass Polish
Plastic trims: CG new Look Trim Gel
My first players
I used both alternatives for the first step to compare. But it’s like comparing bread and apple.
So far Menzerna PG has worked fine for me but it dries so fast and lacks the friendly touch of OHC or Menzerna 203s. Optimum HC slings but the finish is so nice. Sometimes, I felt I needed no need for refining. (Wished I had Menzerna FG500 to try and compare it with OHC)
My pal
My pal and its allies
Just need refining now
I wanted to go the least aggressive way. Without a PTG, My strategy was: sand a little, machine-polish and inspect. Resand if improvement needed.
It cost me so much time, but the outcome was beyond what was expected.
Wait! Wait! It’s not easy to be a moonwalker!
New paint bulges appeared on this panel after I wetsanded. I wanted to get a more level surface but this cycle continued so I let it go. I explained to my friend that this panel needs respray. He told me that the guy who did the paintjob sprayed the paint and clear after without letting the primer cure properly. Still, one has to look very carefully to notice them. Silver colored car!
After polishing and refining
Unfortunately, I could take many pics. I had to move back and forth wetsand, polish, see results and improve. It is so difficult to find the lesser defects on silver-colored car.
Deep scratches remained
Dear friends, how you manage with deep scratches in the absence of paint touch-up repair kits. I mean if you only have the clear coat, hardener, custom paint (of same color) from automotive paint shops?
Glass
The windows were polished with Menzerna PG and LC orange pad. Around the corners, I used Detailers Pride Glass Polish with LC orange applicator pad. Results were very nice thanks God. The water spots disappeared.
After being polished, it has still to be wiped. It was cleaned in and out with Stoner Invisible Glass.
The Headlights
The headlights were wetsanded, 1000,1500,2000 and 2500 grit. Then they were compounded and refined using Menzerna polishes
LEFT SIDE
Before
After
A month later
Right side
Its condition appeared same as the right but it was worse.
Close up
A small hole at the corner, water’s entrance
It was clear, but the glare was there. I couldn’t take the right shot. It still had some water drops inside.
Tail lights
It remained to be buffed with a microfiber
The glass, lights and paint were all cleaned with ONR and sealed with Menzerna Powerlock Sealant. Plastics were treated with CG New Look Trim Gel.
The work was finished at 7 in the evening, 8 days work per 7-8 h.
The only finishing pic I managed:
Almost a month later, my friend came to see me. I was focusing on the car. Yes it had changed since it first came here.
The right headlight is filled with moist and water.
Compared with what she looked before
Now
Craters invaded by shine
From this
To
close-up
The roof
Before
After
The hood
Before
After
The side
If you made it this far, thanks so much for reading
Looking forward for your thoughts and words of advice
Thanks so much
Zaid
Claying
To the defects now:
Extreme close-up
The rear bumper
The vertical panels
Deep Scratches
Closer look
Flake-offs
Space conquest!
Surface prepping
Final Wash n Clay
Ready for Fun
My friends
My first players
My pal
Glass
The Headlights
LEFT SIDE
Before
After
A month later
Right side
Close up
Tail lights
Now
From this
To
close-up
The roof
Before
After
The hood
Before
After
The side
Thanks so much
Zaid
