Superb Sound Quality Power Amplifier For Sale.
1.PIONEER PREMIER GM-X624 an extremely rare high end power amplifier in PIONEER car audio line up. PIONEER PREMIER series is only available exclusively in the USA. All Pioneer high end car audio products such as ODR and PRS in USA is under the PREMIER series. Super clean 50watts x4, High Signal to noise ratio of 105db, Ultra Low T.H.D. 0.004%, Wide Frequency Response 10hz-50,000hz, Load impedance 1ohm-8ohm, Bridgeable 2/3/4 Channel capability, 1- ohm stable operations, Balanced Isolator Input Circuit, PWM Regulated MOSFET Power Supply, Hi-Volt Input Level Control (400mV-4V), Variable Crossovers: 50-120Hz, -12dB/oct. (LPF/HPF) (Front & Rear Channels)High Quality famous ELNA Capacitor and Condenser, Gold plated rca input x2, Gold plated rca output, Carefully selected High Quality internal parts, Current Monitoring Protection Circuit, Two 20 amp fuse. Nonetheless, it's an extremely clean amp at it's rated power. “A truly ‘Premier’ power amplifier” Item brought back from U.S.A. Outstanding power amplifier with smooth beautiful sound. Item is in very good conditions inside out and never been repaired. Specially Made in Mexico. Conditions 8/10. . Price Rm.550.00 nego.
2.Rockford Fosgate Punch 150a2 amplifiers are designed to meet exacting standards of efficiency,space saving and effectiveness. Plug the Punch 150a2 into your system and hear how it lives up to its name —150watts RMS power are waiting to supercharge your speakers or subs! Very underrated, 75 watts RMS x 2 at 2 ohms, 150 watts RMS x 1 at 4 ohms in bridged mode, stereo or bridged mono output, 50-210 Hz high-pass/low-pass (12 dB/octave) crossovers, MOSFET power supply and output devices, MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability, TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise, Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality, TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise, NOMAD — advanced protection circuitry for "intelligent" shutdown protection. Punch Bass Boost(0-18 dB bass boost at 45 Hz) adds even more snarl to the growling low frequencies. You'll appreciate the quality of the special-design pre-amp section and the MOSFET outputs when you drive this amp hard — you'll hear your music loud and clear, with minimum distortion and maximum musicality. Compact and very powerful for it's rated power and size. Proudly Handcrafted in the United States of America. Price:SOLD.
3.Precision Power Industries or famously known as PPI is an American company major in high end car power amplifiers. Here is one of their legend with outstanding sound quality a very rare PPI 4200am power amplifier. Sound quality and versatility are the key characteristics of this gold medal winner. The 4200am performs flawlessly in 4/3/2 and by utilizing a mixed mono configuration, 5 even 6 channel are possible. The 4200am is driven by a twin large power supply and a mighty 32 pieces mosfet transistors. Ultra-Wide Bandwidth circuitry, Power rating in 50watts rms x 4 @4ohm, 100watts rms x 4 @2ohm, 200watts rms x 2 @4ohm bridged, Damping factor of more than 500!!, Adaptive Mosfet switching power supply, Power Bandwidth 10hz--50,000hz and a signal to noise of 102db. Trust me that this is a sought after truly outstanding sound quality masterpiece. One of the cleanest 4 channel car power amplifier ever made. Superbly Made in U.S.A. Price. SOLD.
Check out the PPI 4200 guts-Picture from amp-performance.de
4.For those who are not aware in the 90’s, Sony Corporation of Japan produce a line up of high end car audio equipment such as XM and the ultra high end XES series.
These high quality car audio product only used a high grade carefully selected internal components and this well made Sony XM-6020 power amp has no exception.
Sony XM-6020 power amplifier produce a very high sound quality i.e. good imaging, very wide dynamic range, smooth mids and highs, crystal clear clarity and a well projected vocal that only rival by today’s expensive power amplifier.60x2watts rms of super smooth power- Ultra wide frequency response 5hz-100,000hz- extremely low T.H.D. 0.005%- Rubycon power capasitiors- Sanken mosfet transistors. Suitable for your high quality front stage. Proudly Made in Japan. Price. SOLD.
NOTE:USED ITEMS FOR SALE HERE IS FULLY TESTED, IN PERFECT WORKING CONDITIONS AND 100% AUTHENTIC PRODUCTS FROM THE ABOVE STATED ORIGINS.
For purchase or inquiry please get in touch with JOHAN AIMAN HAKIM @ 017 2687014. Thank you Zerotohundred and thank you all.
