Guys,
I have the following for sale:
No. 1
Item: Greddy Intelligent Informeter
Price: SOLD
Contact: 019-3220520 Zai or sms
Description and Pictures Below:
GReddy Intelligent Informeter designed with a compact plug and play color LCD display, the Informeter allows you to monitor, set warning points and datalog your vehicles performance though it's own OBD sensors. The Greddy Intelligent Informeter is a inexpensive solution to monitor your your veichles parameters via the factory OBD II port. This unit will work with all OBD II vehicles, although, in some applications, only some parameters will be able to be displayed. A cigarette lighter plug powers the unit. Features an easy to read Color LCD Screen, Monitor Record, Playback, and 180 Degree Monitor Flexibility.
This will allow you to read up to 25 pieces of information. Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, and Exhaust Temp.
No. 2
Item: Blitz Type LM Air Filter
Condition: Used but filter still clean
Price: SOLD
Interested? Please contact 019-3220520 or 017-208 3535 (Zai)
Thanks!
No. 1
Price: SOLD
![racinglab_2047_672257150.jpg](http://i5.photobucket.com/albums/y180/suadiablo/racinglab_2047_672257150.jpg)
No. 2
Price: SOLD
![SUSPowerCoreTypeLMAirFilter.jpg](http://i5.photobucket.com/albums/y180/suadiablo/SUSPowerCoreTypeLMAirFilter.jpg)
Thanks!
