FS: EK Digital Climate Control Wiring Harness, Complete Set!!
Hikaru
Atlanta, GA
Up for sale is a complete set digital climate control wiring harness with digital blower, relays and motors for EK. This set is complete with all relays and motors which is hard to obtain these days. Perfect kit for the conversion for those who would like to do the digital climate control conversion such as any of these:
This kit DOES NOT include any of the climate control, only the complete wiring harness, relays, motors and blower for the conversion for those who only purchase the climate control only.
SOLD
What other items for digital climate conversion apart from the wiring harness as advertised and digital climate panel? Can i use the existing EJ compressor, cooling coil and etc?
Bro ....have to take out dash to install this or not?
You don't have to remove your dash, just remove the glove box to swap blower and remove climate control for wiring harness connection.
Shawn
The climate control you sold me earlier is working accept the temp control & the rear windshield heater button. What might be the cause of this? any idea where to get the trims for the 99 climate control like the ones you posted earlier, carbon one would be nice. Rite now I'm using the carbon sticker...looks like s**t
shfish said:
Shawn
Nothing is wrong with the climate control, it's the wiring harness that your mechanic didn't get it right.
For the rear windshield defroster, the 96 is individual on top so you have to take that wire (baby blue + white) and have it taped to the same baby blue + white wire on the 99 climate control wiring harness at the bottom. Or else it won't work.
Temperature is not working because the Japanese models has heater so the air is actually mixed with hot air to control the climate. If you need to know more just gimme a call and I'll let you know how to do it.
Ok ...will try to DIY the baby blue & white cable, meanwhile any source for the carbon trim for the climate control ( the Ori Type R one is very Exp)
Make sure you know what you are doing if you are gonna diy or else you will cook the module. :X-:
There are shops in KL and JB who is doing the custom CF printing or cubic printing and you actually can get them to do so along with your power window switch cover, side air vent and Meter Gauge trim too.
how much is it... which one is use for the ek9 type r...
This wiring harness is meant for 99~00 Digital Climate control, rm350 for the complete wiring harness, blower, relays and motors.
GPS system is not included. You can get the new Malaysia GPS system for 2K~2.5K depending on package that you would like to have.
