Well, if i'm not mistaken, it's plug and play, and only the exhaust cam is different, the intake seemed to be of the same lift and degree, works best with an adjustable cam pulley. :D
still available.........no need to tune or anything......bill sherwood website got the spec for svt n bt cams.....u can check it out......simple n value for money upgrade.......
Hi guys, recently I found my gearbox to be leaking oil but not very severely. I went to 2 mechanic workshops to get a diagnosis and quotation on fixing the issue, both of the workshops said it was the oil seal that needs to be replaced. The first one said it was the right side oil seal which I assume is the driver's side driveshaft seal that is leaking, he quoted me around rm120 to replace it, rm40 for each seal and rm40 for labor charge. The second workshop I went to earlier, they took a...
