ok now racun! go to exss work or jaafar fast fast.! bring big big money.. haha
Hmm.. actually I did went for exss work, and it cost mostly same with jian hang, I would prefer back to jian hang.
I solve my problems already today, used up 380 for a local brand 2" inlet s-flow mid size muffler, and mid section change to a 1.6" inlet 17" long type replica resonator rm360.
Low end was slightly better, but quite a lot different in top end, I din`t have losses after change out my 1.7" straight flow.
---------- Post added at 09:47 PM ---------- 6 hour anti-bump limit - Previous post was at 09:42 PM ----------
Yup, like bro. peeche mentioned google and research. Check into forums too, but don't do first then ask is too late.....
---------- Post added at 08:28 AM ---------- 6 hour anti-bump limit - Previous post was at 08:23 AM ----------
Don't get me wrong. Spending 2k is a lot to me. What I mean is to mod and spend a certain amount I would want so results. I did NA mod many years ago and on forced induction already for 13 years. In fact many new cars are going FI too.....
I understand what u mean, I just wanted to remain NA for this car atm.
I know spending that amount on na sounds stupid, most people would recommended to go for force induction since I`m willing to pay that much.
But I`m really not that interesting to goes for a force induction atm.
---------- Post added at 10:07 PM ---------- 6 hour anti-bump limit - Previous post was at 09:47 PM ----------
Just fyi guys, I've met yewly. This young man quite car gila crazy and his Almera does look quite nice even though his GF pulling his ear long long because of the wing and bump suspension.
So he might be a newbie but he's open to learning and suggestions. So let's all poison him nicely with fair and square information.
Yewly, I think you misunderstood uncle vr2turbo's advice. The fella old mah (he is easily your fathers age) and to him the best way to do things is the 'final' way to do it, not slowly add this add that all the way. Terus BOT. But personally - I don't think your gb and engine will survive a BOT.
Sort out your piping first. Get all same diameter then do something about that midbox/resonator inlet size and outlet size. That thing is causing a massive traffic jam for the exhaust gases.
I had fix my problems today, I had change my mid section into a 1.6" inlet 17" long type resonator, I got immediately improve on pick up on low end, even just slightly. Din`t try on top end.
And after change the mid section, I had change my rear muffler into a 2" mid size s-flow, more or less same low end, but having quite good top end, I got improve after 120, I`m not sure either the mid or rear section, but I have gain.
Oh, and I had install a alternator booster(friend diy) which work quite well too. Its only cost rm150 but its the same with a cari furom monster123 seller rm400 one. Got immediately improve on pick up and cooler air con after that, my stock speaker also got better quality, and brighter headlamp too.
And I fix the hotbits bumpy suspension, I did went back for 2nd time, and they change the setting of suspension. Its getting soft but still remain bumpy, after that my god father calculate it and made a custom order the spring from his friend factory. It fixed the bumpy, slightly soft compare to before, but still remain stable.
Soon or later I will went for tuning house for adjustable cam pulley and lighten crank pulley,enlarge piston and manifold.:proud:
---------- Post added at 10:14 PM ---------- 6 hour anti-bump limit - Previous post was at 10:07 PM ----------
BOT also cannot go all out mah! Any mod must be within the engine limits too. Mine was transplant, and even that I kept as standard transplant and not force it some more.
My friend did and blew two engines in the process.....
I did not have any idea with force induction, I just worried about bot does`t suitable for daily driving.
Turbo got delay, and worry about the uncomfortable. And I also heard bot and supercharger not easy to maintain also.
But I heard bot could be set back something like early boost with low rpm, and they said they could custom something in gear box to make sure it won`t be break so easily.
