After you finish with your full set exhaust mod (Rear mod is a must if you wanted to improve the high touque ) . See how first . if not up to what you expected then perhaps you could do a bit of homework on clutch and flywheel ( 8'' clutch set if for normal use exedy japan made one will be o'kay and 8'' Super Touring flywheel ,both parts should not cost more than RM480 if purchase parts from auto parts shop ).Do your homework and check out the pros and cons .If it suit your expectation go ahead then.
Dunno about branded exhaust coz never use them before.
