boyzone said:So, after replace on the orange plastic cover, have any improvent show ??
Actually I still suffer with this issue ... engine will be stalled intermittenly when clutch press in .
acbc said:I did everything but all also fail... now using super thick welding cable for ground. Idling seem ok now.
boyzone said:change plug ?? can share what type of spark plug u are using ?? install thick ground cable ??
huakenny said:ok...my idling wit aircon OFF is 1.5k rpm n 700rpm with Aircon ON... if there any way for me to adjust the gap between aircon ON and OFF? let's say wit aircon ON is 800 and OFF is bout 1000rpm...
any suggestion or idea? ir carburetor engine i know la....:X-:
boyzone said:ISC is ok ?? if ISC is ok, that'e mean u need to check on ur TPS, sound like calibration out ....
boyzone said:
Similar threads | |
