just want to share something with u guys, if you still using the stock alarm here is a way to arm the alarm system, thks to the SWS (smart wiring system).. kinda impressive to me :P As i read, the original setting for alarm mode is OFF.
i have done mine yesterday, and it works! :_: :_: enjoy trying just make sure close ur ears if ur horne is damn loud!
Information that is being adjusted will be remembered even if the battery is disconnected.
Adjustment mode entry conditions
1. Each switch sets the following conditions.
• Driver’s door switch: ON (Driver’s door open)
• Key reminder switch: ON (Ignition key removed)
• Lighting switch: OFF
2. When the windscreen washer switch is turned ON continuously for 10 seconds or more (by pulling the wiper lever forward), the ETACS-ECU internal buzzer will sound once and the adjustment mode will be entered. While in this condition (wiper lever pulled forward), the settings can be changed when the transmitter unlock switch is pressed.
to change the setting ON or OFF, press the unlock buttom.
• Security alarm function OFF (initial condition): Buzzer sounds once
• Security alarm function ON (warning signal: hazard and horn): Buzzer sounds 3 times
• Security alarm function ON (warning signal: hazard only): Buzzer sounds 5 times
Adjustment mode entry cancellation conditions
1. The adjustment mode is cancelled when each of the following conditions has been met.
• Driver’s door switch: OFF
• Key reminder switch: OFF
• Windscreen washer switch: OFF
• The keyless entry transmitter unlock switch is not pressed for 30 seconds
