Is your car Wira 1.3i? If yes, then the best way to get rid of this problem is adjust the timing. If not mistaken cost rm30 per adjustment. Then after few weeks adjust again and this process will be continue until cannot be adjust anymore. This I will call it a stupid way.simplythebest said:Engine died many times, uncountable times precisely. Must be the fuckerama idling problem, need to tune.
Another question is, i'm using K&N filter for 1.6/1.8 (but mine is 1.3), will there be any problem? Right after I fix this Air filter, the problem occur.
Before this, my idling isn't that bad, but still fugged up I know. I couldn't start the car easily, have to step on the oil pedal when I turn on the ignition.
Any good workshop to do tuning?
Actually Proton injection engines is no need to adjust the timing for normal condition. Now the question is why the car engine will die when idle? Is because the setting run away? Or is it normal for Malaysian make cars? The actual fact is valve before entering to combustion chamber is blocked. For stock air filter it will take around half a year to blocked that will cause engine to die when idling. If using other air filter, mushroom head type, it takes only 1 or 2 weeks to get blocked. So to clean the valve, how much does it cost? Rm1-2 only.
