Engine keep idling.
wira3319
258
7
Hi guys,
Could you help me on above problem? i have change to 4G63 N/A, but the engine cannot running smothly and i suspected from control sensor map. i have change it already but didnt get any effect. i didnt know what to do anymore. the engine cannot running smoothly when i turn on the air cond and regarding from that, the engine also can shut down without any signal...
Regards
wira3319
kennethfong
506
dun understand the topic 'engine keep idling'?? wat is suspected control sensor map? which sensor did u changed? what engine r u using? what ECU r u using?
boyzone
2,669
is ur stepper motor in good running condition?? sound like engine only can be halt when air con is turn on.
g88
3,081
54
check your maf sensor, throttle body, ISC, stepper motor
Hi there,
Can anyone share some info where i can tune a/f and check my O2?
Someone told me to tune this a/f the workshop need to have some kind of michine?
my 1.6 satria fc very bad, superb bad. full tank max is 300km only..
My location is Kepong, hoping someone will give out helping hands.
