Defi vs Shadow
csl
1,285
498
1,683
Malysia
May I know what is the performance different between Defi and Shadow gauges? Example like accuracy, sensitivity and etc. Thanks in advance.:adore::adore::adore:
mines998
1,048
149
663
If want accurate sure go for Defi but if just need a gauge to serve monitor purpose or budget then you may go for Shadow,
fastlearner
136
9
Kota Damn
any shadow gauges user wanna share their thoughts on this? i know its not gonna be as accurate as Defi but for the price, if its at least 70% as accurate, its good enough i guess... pls share ur thoughts guys :smokin:
mines998
1,048
149
663
Boost meter I still prefer mechanical type use for 10years also no problem.
AD_EG
6,000 RPM
6,328
231
Ipoh
how about blitz or apexi meters? about 50% cheaper, doesnt look as nice as defi but is the accuracy as good compared to defi?
mines998
1,048
149
663
Most of mechanical boost are quite accurate beside that for those car with boost cut will limit by ECU and for those got boost controller is control by the boost controller and the boost meter it just serve as monitor. For me is not a big deal.
AD_EG
6,000 RPM
6,328
231
Ipoh
actually my concern is on the oil and water temp....as you mention boost not so much of a concern due to other gadgets...but water n oil temp i need to know.. if accuracy is more or less the same i can look for apexi...trying to avoid getting defi... damn expensive and if car gets broken into............................ my heart will sink
mines998
1,048
149
663
My experience I found Defi gauge temp will slightly higher than those Taiwan brand but how accurate I also don't know because never I validate it. For water temp infact I more trust the oem water temp eventho there are no show the actual temp. Because after market water temp is plug on radiator hose for sure it will have a variance versus oem water temp. Put it this way if your after market water temp show warning overheat maybe it could be due to radiator water already getting less or somewhere leak but it oem water temp overheat it mean it yr engine really overheat.
AD_EG
6,000 RPM
6,328
231
Ipoh
but the stock/oem water temp would move unless its already overheated bro which means its too late.
an aftermarket one will indicate as the temp is going up, so you can prevent running the car while its boiling....
thats the thing about defi, maybe its highe cause its more accurate etc...i prefer to get another jap brand for water n oil temp...hope somebdy can give a review on other brand besides defi
mines998
1,048
149
663
If you don't want Defi then maybe can try other brand lo...but then price also quite high.
AD_EG
6,000 RPM
6,328
231
Ipoh
ya la thats the thing...not i dont want defi bro...i want....but the price killing me...
i saw like apexi blitz at least got hlaf price diff ....
mines998
1,048
149
663
If you have a budget concern buy Taiwan product also OK beside that if the sensor spoilt also won't so costly got one more benefit is your door glass also can reduce risk of breaking. :listen:
hey all,
any good tool shops around leisure mall area that sell garage tools such as timing light, support jacks, hydraulic floor jack, etc.
around tmn midah, phoenix plaza, tmn len sen, leiure mall, tmn connought would be good. don't intend to travel far.
thanks. :)
pls provide a contact number and an address.
