CRC MAF cleaner
koolspyda
2,889
55
5,148
KayEl
koolspyda.blogspot.com
in some spray ie carb spray; residue (a little greasy is requried/left behind when there is moving parts)
contact cleaner as the name suggest is used for sensors / electronic boards / diodes.
you can purchase the CRC MAf sensor cleaner (red can) as attached image & later compare with the CRC contact cleaner (blue). just spray a little on your hand. it should leave no residue & it will quickly evaporate (alcohol/methanol base i think).
because can is pressurized, hence when directed to the sensor (dont touch but 4"-6" away), it blows off dirts or contaminants that may have built over a period of time. more so with cars with open pods filters. pressurized cans do have a plastic hose.
though maf sensors will also eventually comes with a product shelf life. esp for tuners readings may deteriorate after some years (even with care cleaning). these were debated in some forums before.
if one cant afford to change maf sensors every 6 months (instead use contact/maf sensor cleaner), then change a new one 3-6years later.
speed2horizon
2,798
334
1,683
But mind sharing where to buy the sensor cleaner..?
normality78
3,052
23
5,138
JB
u shld ask how much is the sensor. hehehehe
speed2horizon
2,798
334
1,683
So, u are hinting that the sensor clear will cost a bulk..?
Hmm... I'd say it's something subjective. Just like turbo. Got problem with turbo, Overhauling a TD04HL cost RM700-RM800. A second hand TD04HL will only cost RM500-RM600.
But buying a used TD04HL may have the same problem also cause it's used and we don't know how it's being used.
normality78
3,052
23
5,138
JB
the last i asked, 1 brand new MAF sensor can talk about thousand.
speed2horizon
2,798
334
1,683
Sorry..? I mean I just dunno how much the CRC spray cleaner may cost. Cause the used MAF sensor will cost around RM60-RM100 depending on model/seller.
Could you please let us know roughly hou much would the CRC spray cleaner will cost..?
koolspyda
2,889
55
5,148
KayEl
usually many dont change sensors like changing socks as cost can be exhorbitant for some cars. some tuners are (can be) anal about readings so after a few years they opt to change a new one.
maf sensors range under rm300 to thousands (well u know la some cars)
Bump: usually many dont change sensors like changing socks as cost can be exhorbitant for some cars. some tuners are (can be) anal about readings so after a few years they opt to change a new one.
maf sensors range under rm300 to thousand (well u know la some cars)
CRC can (bleu) = rm38+ onwards. depending on can size
normality78
3,052
23
5,138
JB
If i was nto wrong, the CRC maf cleaner i posted is around rm80
speed2horizon
2,798
334
1,683
Any idea where to get..?
speed2horizon
2,798
334
1,683
I only manage to find the contact cleaner from ACE hardware. But i bought other brand cause the price only 1/2 of CRC. However, i noticed that the CRC alcohol content is higher. It feels cooler when sprayed on hand.
koolspyda
2,889
55
5,148
KayEl
hence leaves no residue. evaporate fast.
by spraying at sensors it removes surface contaminants/dirt. try not to blast too close. there are some other brands contact cleaner (red bottle) leaves some greasy residue. NOT recommended!
speed2horizon
2,798
334
1,683
But i curi curi tested the thing on hand... Realize that the CRC's have higher alcohol content. The CRC's freezes more. The smell reminds me of the VCR tape cleaner that everyone has once upon a time. lol
AD_EG
6,000 RPM
6,328
231
Ipoh
bought mine CRC opposite PJ hilton and near KFC. There is a few spare parts dealer there. this shop is not facing the main road. They seems to have a complete range of CRC products.
took this from bimmer forum.
some say can get from brothers. anybody can confirm this ? has anyone seen or now where this can be bought? i tried ace hardware, didnt have.
deVilz Inc
68
11
3,008
Carjunk
I bought the CRC MAF cleaner about 1 year plus back from a row of spare part shops around the Jalan Tandang/Seksyen 51 area. If u travel along F. Hway heading towards Sunway, you can see this row of spare parts shop on the left after you pass the 222 exit.
Of course there is no direct exit to the shops via F.hway but if i remember correctly; to get to the shop you will have to exit at 222, head towards Assunta hospital, turn right at the first roundabout (toyota topmark showroom) which is before the hospital and take the first right before Wisma Campbell and go all the way straight till the end of the road. The shops should be on your right. it was around RM40 only at that time. Hope this helps.
Similar threads   Forum
Car Talk
  Similar Threads
Car Talk
<img class="alignnone size-medium wp-image-33296" src="http://www.zerotohundred.com/wp-content/uploads/2012/07/wrc-600x337.jpg" alt="" width="600" height="337" />
It is the grueling challenge in testing the bond between man and machine, going against everything that Mother Nature had in her arsenal. Let it be sand or snow, scorching heat or heavy down pour, these are just half the elements that the skillful and daring rally drivers would have to face before reaching the finishing line...
