hi hoongss, sorry as i am totally new to this openport thing.
my ride is Evo8MR, which items i will need to buy?
i will need to buy all 3 items as below ?
(1) Tactrix Openport 2.0 $169.00
(2) Mitsubishi Reflash Connector $11.00
(3) OBD2 Extension Cable $15.00
to connect the ecu to the laptop, i need to insert the "tactrix openport 2.0" to the OBDII, is it under the steering wheel ?
what software i need ? is it only "EcuFlash" i need which can be downloaded from the website? free of charge?
thanks in advance
You need 1. tactrix openport 2.0, and 2, mitsubishi reflash connector. you do not need the 3. obd2 extension cable.
tactrix plug to the obd2 under steering near the center console. reflash connector plug next to the obd2. if you see under ur steering, u will see two plug in evo 8 and evo 9..
ecuflash is free if you got the openport cable. ecuflash is a software for you to read and write your ecu.
then u will need evoscan or similiar software for you to log. evoscan i think is around $20. cant remember.
how about the risk if i mis-flash the ecu ? like..... suddenly laptop hangs or whatever....
happened to me once. but my car is evo x, not sure about other evos. i got the blue screen while flashing. so basically is when you are writing your ecu. ecuflash give command to ur ecu to stay in write mode so that it can do all the work, after it done writing, it will then exit the write mode. you wont be able to start your car while on this mode. so what happen to my car is i can put the ignition to on, and the car will turn on, but i could not start the engine. so in order to solve this, you got two methods.
the easy method... restart ur pc, and command ecuflash to stop write mode in ur car. i have no luck in this method...
the hard method... brick your ecu.. go google how to brick evo ecu.. it is PITA!
