thank you very much bro appreciate it.still googling this transistor/smd with "GA" marking.what I found is a zener.But I m pretty sure it is a NPN transistor.
Try look for a Switching NPN TR with following spec...
Vceo = 60V
Ic = 1A
hFE = 100~200
FYI, "GA" has a built in protection diode across Emitter and Collector
will this work 2SD2403 or FMMT493A are this available in our market. BC639 might work regarding to this sitehttp://www.toymods.org.au/forums/tech-conversions/75164-relay-switches-only-5v.html
2SD2403 is direct fit but doesn't have the built in protection diode. You need to add a separate diode across the relay winding.
FMMT943A spec is Ok but have diff foot print. Some mod is needed.
BC639 is lead device not SMD. Again, some mod is needed.
---------- Post added at 10:18 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 PM ----------
I have the TR from donor board. If you want can come and get it ah.
My Altezza was broken into last week, and the stereo from it stolen.
the crooks took the center console bracket along with them. (placed just below the aircon unit) Picture attached.
I am looking for anyone can direct me for that...
