Bigger Rotor!
starscream
147
What is the biggest rotor size that will fit a standard mitsubishi twin pot caliper? or can we increase the size of rotor without changing stock rotor? anyone here knows?
jinkl
4,624
376
3,183
dont understand ur question at all , "increase the size of rotor without changing stock rotor" huh... blur
starscream
147
sorry! i mean can we increase the rotor size without changing the CALIPER. what is the maximum size rotor that will fit into a stock mivec caliper!
jinkl
4,624
376
3,183
why would u need to change the rotor size bro
the standard size is the best
starscream
147
its the same reason why everyone ask question here. stock engine & car is the best, but why do we still modify?
jinkl
4,624
376
3,183
oh but this is diffrent, if u dnt upgrade caliper , the brake pads is not going to touch the extra part of the bigger disc , so no need put bigger rotors , no extra gains.
starscream
147
icic. thanks. noler i saw some disc are lager in overall diameter but a smaller friction surface. Did not mind the gain as i want the looks, as long the performance remain the same.
boyzone
2,669
38
5,148
With the std brake pad and caliper, changing to larger diameter of disc rotor able to gain more distance to grip with the same turn.
It should be help to increase braking performance. However, no idea on how significantly different on the braking performance as I still run with stock as well.:biggrin:
Just my 2 cents.
boyzone
2,669
38
5,148
No idea as I still run with stock... However, 2 pot caliper should work fine already.
my questions:
1.) how much is 195/50/15 for Advan Neova? New price plus installation, balancing and alignment.
2.) comments about Falken Ziex?
thanks
