Basic Performance upgrade
stutzedward
3,416
561
Yes. The cover not only prevent heat exposing to all the parts in the engine compartment, it'll also prevent water from contacting the manifold during rainy days.
stutzedward
3,416
561
Mine not completely closed. Can still divert air and rainwater onto the rocker cover. I'll whatsapp u.
---------- Post added at 02:55 PM ---------- 6 hour anti-bump limit - Previous post was at 02:45 PM ----------
Sent!
stutzedward
3,416
561
Ah Wah completely sealed the hole but I do not want to. So I open a gap for cold air to enter the engine compartment despite knowing water will slip in. So far it's working well in all conditions.
It wasn't too nice looking even after I sprayed it black. So I applied C/F stickers on it to look more standard with the CF scoop.
stutzedward
3,416
561
So bro 4gbanger, any updates on your TD05 + FMIC performance? Hows everything? Have you done the dyno tuning yet?
biao
348
24
518
perak / ipoh
On last Saturday just do some upgrade and maintainace service.
1) Engine Oil
2) All gear oil ect: ATF, LSD & mid-axle
3) change all vacuum hose to silicone
4) Add fuel regulator Works brand
5) Add Boost controller(manual) Works brand
6) ground cable HKS
7) oil catch tank D1spec
ken yeang
6,000 RPM
6,617
1,327
1) Engine Oil
6) ground cable HKS
So, did the upgrade you hv listed improved the performance of your car?
stutzedward
3,416
561
Stock boost is 0.6. I've pushed it to 1.3 no problem with stock mappings and stock hardware. Just make sure car in good running condition.
---------- Post added at 07:55 AM ---------- 6 hour anti-bump limit - Previous post was at 07:47 AM ----------
Increasing boost will see an immediate improvement in power.
Wow! 1.3, I thought safe point probably 1 only.....:adore:
hi guys.. relatively new to car accessories and mods....
need help in a couple of simple Q..... hope u guys can help out..
1. whats a "spark" as in "pivot spark" use for ?
2. heard changing crank pulley can increse the car hp n torque rite.. any guys here done it ? ....
3. read in some mag tat says..... changing cam pulley also can increse power....(i only heard ppl changing crank and not cam pulley) .....any 1 of u guys changed r cam pulley ?
main Q = if any 1 change crank and cam...
