Xcuse me..Hope sifus here can help me a little bit.
1) Can i make B18C (GSR) 180PS(176HP)@7600rpm to the level of B18C-R 200PS(197hp)@8000RPM only with this mod :-
-B16A 1st gen integra head (pnp done) + B16B intake valves + B16Bcams + B16A exhaust valves + B18C-R intake manifold/throttlebody/injectors/fuelrails
-the bottom end is B18C GSR with B16B pistons (10.8:1)
-OBD0/small V wirings n ecu (rechipped) isntead of Type-R ecu n wirings.
-aftermarket headers
2) What's the difference between B18C GSR block compared to B18C-R in terms of it's crank and conrods measurements,weight and material?I only knew that its pistons only had 10.6:1 CR while B18C-R is 11.1:1. Is it safe to put in TX3 83mm pistons while the standard size for B18C is only 80mm?
Thank you..
Thank you..
