Ae100 bad petrol smell
kelvin_jay
947
8
Any taiko can assist i facing bad petrol smell after switch off the engine and charcoal canister got buzzer sound. Anyone facing this kind of problem before??
KenDiriwan
1,283
225
3,163
kendiriwan.multiply.com
Are you running any fuel regulator? Check at all of the fuel lining from petrol tank all way to fuel rail. Torn hoses are possible cause.
If hoses not good, then will leak all the time, not only when off the engine, right?
KenDiriwan
1,283
225
3,163
I once had a loose clip around my regulator, it did not leak every moment though.
Then have to check. I once had a leak, but very very small but still can smell. Upon checking one part of the hose was starting to crack and if bent it the leak becomes more.....
Guys,
I like to start a thread on methods you have heard (or experienced, gulp!) how people car jack. The methods I know are:
1) Sticking a note on your rear window (when your car is parked), so when you exit your car to check, the car jackers get in and drive off your car
2) Like no. 1 but they stick cans on your exhaust, so when you drive off the parking spot, you hear noise behind you. You go down and check, and the car jackers move in.
3) They ram your car rear on the roads...
