powergigi,glad to hear that u like it.
t_trax100,it would be very stiff for ur car.the suspension is attended for
evo4 that weighting 1380kg while waja only tip the scale around 1200kg.
that's not all,evo4 is a 4wd car while ur's a ff car.as i mention before,the
spring rate tend to be the same on all 4 corner to avoid the evo squat
while accelerating.this suspension is as stiff as hipermax 2 n tend for
drift or gymkhana where u go fast in a tight corner.imo,it will be stiff for
u unless u like stiff suspension.
about the knob,i can remember which way to harden n soften the damping
of the absorber.about the nut u mention,i realy don't know.maybe it's there
so u can add more gas in it to make it more stiffer or it tend to make
the suspension more easier to service..:regular_smile:
but its really bumpy when i travel on straight road...on uneven road its still ok..when i put it on soft,its more worst.....really headache...haha..
don buy halfcut abs la.....tend to be very very hard like track car, why don u buy a new set of gab, hwl, hotbits for ur car? so uc an pair with different spring to ur car to suit ur taste....more easy for u also...if u wan combine racing n comfortable then use gab or HWL hi low soft hard abs...got warranty somemore
my wira using HWL MT-4 hi low soft hard, 8k front,6k rear spring rate.
if i wan take peopls then i just turn the knob under the car to harder then even u lowered ur car too low also can prevent those hump....or u wan comfort then turn the knob to soft then will be like performance ABS.....i bought for 2400++
Similar threads | |
M | |
Similar threads | |
