Adjustable Cam Pulley on 4g93vdo
ahmad84
226
Hi all,
I have a question here, hope u all can help... i bought a works adjustable cam pulley, last weekend when i want to install the cam pulley, the mechanic said can't because mine is satria gti with siemen ecu. hesaid if install, gonna "kacau" the cam sensor. Is it true?
Thanks all...
ahmad84
226
skywalker - old gti and gti with siemen ecu the cam pulley the same kan? the 1 i bought for 4g93.
xtremeleo - that's what the mechanic said.. i also dunno...
xtremeleo
3,247
464
5,183
they are the same imo
i dont think the vdo ecu can alter mechanical settings, it can adjust the electronics accordingly but up to a certain degree. i think its do-able, pm for more details sir
93na
597
20
can be used but cant set max! only a little! if to much will mess the timing! since u bought it already just fix it! if scared anything happen just used back standard setting!
looks better than standard!
bro my advices ah! if ur gti is using vdo system better leave standard! if u really wan to mod! then change the ecu to mmc wan! if not just leave it!
ahmad84
226
it hard to find the complete set if want to change mmc ecu..
93na
597
20
can! try mudah.com..... take ur time search around!..... i mjust saying if u intent to mod! but if u wan to used standard then just leave it!
xtremeleo
3,247
464
5,183
WHY? WHY DID U DO THIS TO US LAA PROTON???!!! TIMKAIYA??!!!!
haha, i think we can work around the limit parameter kot.. what was the result when u installed them in the biatch sir? wud luv to know what happened, tq sir
93na
597
20
no i have a 1.5 wira wit vdo system!!! it sucks timing messy! fuel very high, no power!
fren gti wit vdo! did so much mod! cant even follow wit mid mod gti wit mmc ecu! his gti when on air timming falls to 600 can feels like dying!!!!! put ficd no diff!
vdo system suck! is a pain to mod wit this system! plus the part are nit cheap! tb standard vdo from proton 700 to 800 hundred!!! if mmc can put s90 already ha ha ha!!!!!!!!!
xtremeleo
3,247
464
5,183
wahlan!!!! its sure is a pain in the arse dis vdo laa, timkaiya laa proton?????
guys.. need your help and opinion..
can fto dashboard fit satria or not? have u heard about it? ok or not ??i heard that evo4 dashbord can fit wira with some mod..but how bout fto... i want to try la...:shades_smile:
