- Joined
- Nov 7, 2005
- Messages
- 922
- Points
- 5,018
Hi selling brand new Adcom GFA-4404,I have 3 unit.
Price : Sms/Pm/Whatsup
Contact: 0162510646
This is one of the most sonically superior amps currently on the market and even the competition thinks so. The GFA-4404 is exquisitely designed all the way down to the circuitry. The internal workings of the amp are beyond extraordinary because of the multitude of features its has respectfully been endowed with.
Ok enough of the hoopla. Let's get down to business this amp is capable of 300w rms split by 2, that's 150wrms for ch 1 and 2 and 150wrms for ch 3 and 4. To keep everything cool and functioning efficiently the amp has a cooling fan. Its impedance handling capability is very low, and allows the user to patch it into a multitude of subwoofers or mids and highs.
It also is able to power a center channel which add to the depth and realism of the music. The balanced line input is one of the clearest in the car audio business. It blocks any noise that is associated with ground loop interference or engine noise.
Amp that are rated at over twice the power can't even come close to touching it at any level of play. The frequency range is far beyond what other amp are able to play, from 0Hz-50KHz. The signal to noise ratio is awsomely high, rated at 100db, which means the sonics come through loud and clear. The damping factor is superb, around 600 which means it blocks a lot of unwanted noise and only plays supernatural music at astounding rate of quality.
I love this amp as well as all other Adcom products. Although a bit high in price its well worth the money!!
4ohms = 40w per ch at <0.1% THD
2ohms = 80w per ch at <0.25% THD
9.75x24.25x2.3” and a solid 19lbs
XLR Balanced inputs
It is a pure class A amplifier. Not A/B, D, T, etc etc etc. Nelson Pass is a legend in class A amplification design. While there are plenty of amplifiers which make more power (this thing is severely underrated), there are very few amplifiers which can match the quality and clarity of these specific Adcom amplifiers. Not to mention they are stable to less than 1/2 ohm. This is also only 1 of 2 amplifiers ever brought to market which was 100% pure mofset circuitry. If you know Nelson Pass than you know this signal path is uncluttered.
Contact: 0162510646
XLR Balanced inputs
