About Tyre Size
masvidal
253
Kota Kinabalu
Hi everyone.
Currently im using 195/50/15 tyre size.
But, for the next change im considering for 205/60/15 or 195/60/15.
The question is, can i use that tyre size? any pros and cons?
Reply is appreciated.
masvidal
253
Kota Kinabalu
forgot to mention. my car is proton wira. currently using lowered spring. 2 inch gap at back and 2 1/2 inch gap front. my rims size is 15 x 6.
my only concern is that whether the tyre will hit the fender or mudguard, especially at the back.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
195/55/R15 tyre is ok oledi.....ur rim not wide enuf..cant put 205 tyre i guess......
should be 15 x 6.5 or 15 x 7 is beter
zealless
163
Melbourne / KL
yup ... he is right, u need 15x7 to put a 205 ... if you don't have turbo, it might actually slow you down when you lauch ... cos u got more grib ... good enuf setting for a wira ... even integra R use 195 i think ...
masvidal
253
Kota Kinabalu
ok. thanks for the reply.
60 series can fit or not? will hit fender? anyone had try this setting?
im considering higher profile tyre bcoz lot of deep potholes here in my area.
zealless
163
Melbourne / KL
Not sure, better don't, probably you will scratch the fender when you turn the steering ... borrow someone 60 and try lor ... best way to know ...
amad108..
416
5,018
15 inch with 60 series same with perdana standard rim's, my friend use it in his saga just nice but his abs very damn hard...
by the way, why u want to change to 60 series? for wira with 15' 55 series just nice..
cldc2
39
far away
masvidal said:
thanks. all comment noted.
205/60/15 is evo3 stock tyre size.
i think 195/55/15 should be enough. If your car modified? otherwise the extra 10mm on each tyre will just give you more drag on the road.
evo3 got no plastic guard?!?
Looking down on to the centre console, centrepiece of the Macan's pretty cockpit, a range of buttons surround the shift knob. Everything from air con to ride height to driving mode selection are concentrated here. It will take some getting used to, to start operating this intricately arranged command centre to its full potential...
