About Skyline R34
Tatsumaki
Hello greeting to sifu-sifu, I plan to get a R34, but I think I need more info about it, like the common problems of the car, the engine stuffs and so on.
So any Skyline owners here and any Skyline pro here can help me up, maybe?
Thanks.
Hey I just thinking of R34, and this is crazy but what's the problems so help me maybe. :biggrin:
Nothing major. Been driving mine since 2006 as a daily driver. Never did it once break down on me. If the previous owner(s) takes good care of it, it'll be literally problem free.
my advise is ( don't mod )....but i bet you will be itchy to do it...:smokin:
Got mine as my daily driven ride since last oct.... So far so good... No prob... Except for the fuel bills.... And anothef thing... Pls change all wear and tear parts as most of the cars are almost 10 yrs old.... Stuff like radiator, brake lines, etc...
Other than that, the only problem is not to mod it.... hahahaha
big holes indeed....change tires also "pening"....hahaha
a bit high fuel consumption ..... XD
Altis RM70 ron95 - 550-600km
R34 GTT RM 70 ron95 - 250-280km
RB26DETT
Displacement, cc 2568
Engine model RB26DETT
Max.power (Net), kw(PS)/rpm 280 ps (205.94 kw) / 6800 rpm
Max.torque(Net), N*m(kg*m)/rpm 40.0 kg*m (392.27 N*m) / 4400 rpm
Power density 5.57
Engine type Water cooling serial 6 cylinder DOHC24 valve IC twin turbo
Engine information
Fuel system NISSAN EGI (ECCS) (electronic gasoline injection)
Turbocharger Twin Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 86
Stroke, mm 73.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 12.3
RB25DE
Displacement, cc 2498
Engine model RB25DE
Max.power (Net), kw(PS)/rpm 200 ps (147.10 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 26.0 kg*m (254.97 N*m) / 4000 rpm
Power density 6.85
Engine information NEO straight 6 LEV
Turbocharger No
LEV system (Low emission vehicle) Yes
Compression ratio 10
Bore, mm 86
Stroke, mm 71.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9
RB25DET
Engine model RB25DET
Max.power (Net), kw(PS)/rpm 280 ps (205.94 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm 35.0 kg*m (343.23 N*m) / 3200 rpm
Power density 5.11
Engine type Water cooling serial 6 cylinder DOHC24 valve IC turbo
Turbocharger Turbo with intercooler
Compression ratio 9
Bore, mm 86
Stroke, mm 71.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
Fuel consumption at 60 km/h, l/100km 5.7
RB20DE
Displacement, cc 1998
Engine model RB20DE
Max.power (Net), kw(PS)/rpm 155 ps (114.00 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm 19.0 kg*m (186.33 N*m) / 4400 rpm
Power density 8.58
Engine information NEO straight 6 lean burn
Turbocharger No
Compression ratio 9.5
Bore, mm 78
Stroke, mm 69.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 8.3
The stats on consumption a bit overrated I think... Even in stock form, mine used to go max only 300Km per tank.
RB26DETT
Power density 5.57
Engine information
Bore, mm 86
Stroke, mm 73.7
Final gear ratio
RB25DE
Engine model RB25DE
Power density 6.85
Turbocharger No
Bore, mm 86
Stroke, mm 71.7
Final gear ratio
RB25DET
Power density 5.11
Compression ratio 9
Bore, mm 86
Stroke, mm 71.7
Final gear ratio
RB20DE
Engine model RB20DE
Power density 8.58
Turbocharger No
Bore, mm 78
Stroke, mm 69.7
Final gear ratio
What it means by lean burn for rb20?
