- Joined
- Sep 20, 2004
- Messages
- 16
- Points
- 3,001
halo.
wanna change mods style.enuff with/dont want drag or top speed anymore.the engine should have strong power band between low to mid rane rpm bcoz want to use on road & most important ,want excellent cornering/handling.
what the formulas frens?
i dont want to use TD05H-16G (been using this for long time)...which garrett gt good for low to mid range? gt2540 or gt 2835 ? how much these two turbos?
as for engine parts..changing only to metal head gasket,ARP bolts/studs,tomei 264 cams,adjust feul pressure regulator, exedy hyper single+flywheel only.maybe tial 40mm external wastegate. other parts like pistons,rods etc oem Evo III.
can all these hold up to 1.2bar safely?
the 510cc injectors enough or not at 1.2bar? and how about fuel pump? upgrade or not?
i want to maintain the oem ecu...need advise on which method of piggyback to use.
change ecu chip+safc wolud be enuff ?
cannot spend too much on engine..wanna spend on good set of suspensions.
any advise on engine please....thank u
