I have to rebuild my engine
my current specs
EVO3 head
Stainlessteel i/c pipings
3" full piping
exedy semi racing 3 puck
greddy type r bov
e3 i/c
e3 non lsd gb
sard fuel regulator
walbro fuel pump
vr4rs block
1.5mm metal gasket
e3 turbine + magic
custom ecu with 2 map switching for hi-lo boost
electronic boost controller
38mm tial wastegate
510cc injectors
bt since i already have a 2nd car for daily drive, i wanna make this one a monster.
My aim , responsive engine with high boost capability , ignore the tuning i got a tuner for that
my plan :
pistons
- 1jz pistons
- sr20 pistons
- vg30 pistons
- wiseco 8.3:1 compression pistons
- wiseco 8.8:1 compression pistons
- arias 8.8:1 compression pistons
- JE 8.5:1 compression pistons
- JE 9:1 compression pistons
conrod :
- vr4 conrod
- eagle h-beam
- eagle i-beam
bearings :
- clevite bearings
injectors :
- 660cc evo injectors
gearbox :
- lsd gb mitsubishi evo3
cams :
- 264/264 cams
important things is i want response
so which combination you think would be good , i dont want to touch far
just 350hp on wheels , high boost of 1.8bar. suggest me , kill me , strangle me , shoot me , i wanna know whts on ur mind for a perfect responsive monster
my current specs
EVO3 head
3" full piping
greddy type r bov
e3 i/c
e3 non lsd gb
sard fuel regulator
walbro fuel pump
vr4rs block
1.5mm metal gasket
e3 turbine + magic
38mm tial wastegate
510cc injectors
my plan :
pistons
- 1jz pistons
- sr20 pistons
- vg30 pistons
conrod :
- vr4 conrod
- eagle h-beam
- eagle i-beam
bearings :
- clevite bearings
injectors :
gearbox :
cams :
- 264/264 cams
