- Jun 3, 2004
- 197
- 5
- 3,018
Take a look at the picture and you will notice that the quality is right on par with other 4G63 H-Beam rods. These rods are rated for 600 crank horsepower. 3/8" ARP hardware are used on all RPM Performance rods. These rods only work with pistons that have full floating pins (NOT STOCK PISTONS). These rods match up very well with Ross or Wiseco pistons and have been tested with both to work very well. These rods are only available through Rpm2 Racing Malaysia.
4G63 6 Bolt Rod Specs -
Rod Length 6 Bolt - 5.900"
1.771 6 Bolt Crank Pin
.826" 6 Bolt Piston Pin
1.117" 6 Bolt Big End Width
4G63 7 Bolt Rod Specs -
Rod Length 7 Bolt - 5.900"
1.771 7 Bolt Crank Pin
.866" 7 Bolt Piston Pin
1.038" 7 Bolt Big End Width
Fitments - 6 Bolt Models
1990-1992.5 Mitsubishi Eclipse 4G63
1990-1992.5 Eagle Talon 4G63
1990-1992.5 Plymouth Laser 4G63
Fitments - 7 Bolt Models
1993-1999 Mitsubishi Eclipse 4G63
1993-1997 Eagle Talon 4G63
1993-1999 Mitsubishi Galant 4G64 2.4L
2003+ Mitsubishi Evo 8 and 9
2001-2004 Mitsubishi Eclipse 4G64 2.4L
Save your Money with a good quality 4340 steel Forged Rod
Syahz's FotoPage - Fotopages.com
[email protected]
[email protected]
