2 way Radiostar alarm ----turbo mode problem !!!
pascalladal
québec, Canada
help.....my turbo mode does not work.....it work one time at 1 minutes when a shutdowen my car...after i go in option and i set to 3 minutes before the car shutdown....but does not shutdown...im not able to go back il 1 minutes setting...so nothing work at this time ...help me ...thx
sti-3366
46
Hi there
what model is that? Leopard or dragon or eagle?
sti-3366
46
NoName said:
Hi pascal,
Can you explain in detail step by step what did you do?
please call Adrian 012 508 0281.
Hi NoName
I've installed the Dragon. So far so good but is the alarm built in with turbo timer?
I'm not aware of that . Thanks
pascalladal
québec, Canada
its a king eagle alarm...
step by step....hummm..ok...
1- install this system lol
2- test the basic setting
3- set the option like i want...
4- set de turbo timer mode... and try in a default mode ( 1 minutes ) it work.
4- set the turbo timer mode to 3 minutes...does not work and not able to back ti 1 minutes...not able to desactive the trubo mode fonctionn.....
5- i need help !!!!
NoName
818
Hi sti,
No, King Dragon doesn't have turbo timer. However, your pre-installed turbo timer will still work.
sti-3366 said:
Hi NoName
NoName
818
I meant step by step how you change the setting.
There's a possibility that you've disabled turbo timer function.
5- i need help !!!!
integramania
2,336
Hi there.
U will need to check with your installer as if it works the first time it should continue to.
Also like Noname mentioned you may need to try it out again step by step using the manual.
Sorry can't really help you in this sense since your all the way in Canada.
Cheers mate!
spec.check
141
pascalladal dude,
you are amazing man. Buy from someone in Canada and then ask the sole distributor from Malaysia to assist. Boy,..are you lucky that these guys even acknowledge your questions.
Who u bought them from dude?
cheers,
spec.check
The Marketplace Top Posts
Anyone done this?:)
Can this be done?
if cant what is the main problem ?
thx all sifus in advance :D
