15"rims-need help
ettm_14
605
81
Hi guys,
Would be great if you guys can help out, I have just changed to a 15" rims, but when I brake, my left side brake will shake(warped?) or vibrate with the sound "Grrrrr..." like a grinding sound, and my car seems like refuses to stop. It is only on the left side.
I did my balancing and alignment prior to this.
took out the tyre and tried to fix it in properly, still the same, could it be something to do with my brakes or the rim size?btw way I am driving a Proton Wira. The rear tyres has no problems whatsoever.
On top of that, would the speed shown on my speedo meter be affected after the rim change?since I was using 13" prior to this.
Thank you in advance.
Rgds'
tofu_manic
1,342
91
5,148
need to noe ur current 15 inch tire profile, and ur previous 13 inch one as well...then can tell
davidv00
952
7
Selangor
my friend facing similar problem and found out it was the rim bented. check for cracks and oval bent.
zac
1,347
231
Johor Bahru
i had exactly the same problem... changed brake disc and bearing then solved, cheaper option is to skim it... No need to worry for rim since you have done wheel balancing unless its not carried out by good mechanic...
ettm_14
605
81
thanks guys, will see to it...very irritating the sound...
2019 Proton Saga Launched! - RM33K onwards
There it is, the latest, most evolved Proton Saga since the Proton x Geely partnership is finally here. It is also Proton's best selling product - contributed a staggering 2 million cars, literally half of the national car maker's 4 million vehicles sold since...
