4age gearbox use on 4agze
abugarcia
all sifus here.newbie wanna ask ques regarding 4agze g/b.can i use 16v/20v 5sp or 20v 6sp g/b
on my 4agze?headache bout the drv shft.any bad effect for the fc,wear n tear part,n also to the engne? tq all sifus...
Yes, 4AGZE can use 4AGE gearbox no matter 5 speed or 6 speed. As long as you have 4AGE drive-shaft, flywheel, clutch cover and plate.
yes u can use 4age gear box in 4agze engine. as long as u have all the thin like drive shaft , flywheel and racing clutch recommend. cos scare is normal clutch to slip.....
cos i using it now....
tq sifuss...so how wasit doin?got any diffrnt wif fc?what kind of clutch u use?
4agze gearbox is stronger. if u use c56 u will get shorter ratio, quicker. if got LSD much better due to SC higher torque..my 2 c
i hv do some research n find out the closes ratio n final drive wif gze gb is 4age 16v gb.bt in my mind its like wan to try 6sp gb.any sifu has xperiance 6sp gb wif 4agze?:idea:
i using exedy 3 puck clutch
---------- Post added at 02:52 PM ---------- 6 hour anti-bump limit - Previous post was at 02:50 PM ----------
6 speed gear box in 4agze you can feel the power than 5 speed gear box.
Actually am using now...
so sifu tan2000.how bout fc?better than e58?long distance?
think almost same la... But at highway is little bit save.... As long as your pedal not to press all and the super charger light is off. Not on all the way,,,, hahaa...
But the final gear also same as 5 speed....
sifu..would appreciate if can had a ride in ur car
