zc twincam dohc
elvis3000
gv me some tips about my EF3 JDM ZC DOHC
1, use sr20 turbo (come 4000rpm)?
2,port n polis head
3,store piston n rod
4,ecu 0bd0 (what is the best ecu to use) stand alond?
5,510 evo injecter
6,255 fuel bump
7,gasket (double)
how psi i can run and safety 1000rpm 6800rpm
bro is not how much psi u wan.. is how much hp u wan for ur engine...
---------- Post added at 10:02 PM ---------- 6 hour anti-bump limit - Previous post was at 09:54 PM ----------
2,port n polis head
5,510 evo injecter
6,255 fuel bump
7,gasket (double)
turbo u can try using td04l from gsr
port and polish head not necessary... if u got money u can do it..
piston and rod u can use back unless u are going for higher hp then u need to change it..
ecu.. seems u r using obd0 u can rechip ur ecu..
injector 450cc is enough...
fuel pump u can use back ur stock fuel pump not necessary to change..
can tell me turbo is t3/t4 ? in ebay. all both on kit using this turbo.
i think t3/t4 is a bigger turbo compare to td04.. so higher rev to spool it.. stick to td04 unless u aiming for high hp in the future u can use t3/t4... normally i see honda ppl using t3/t4 are fully build engines..
T3/T4 is a big turbo to supply u power all the way to 3++hp. However, if u use ur car for street driving, the lag is crazy. It'll roughly kicks in ard 4kRpm. Then u'll feel the pull. Highway, nice. 1/4 miles also nice. But there's alot of other supportive modification to make it feels nice.
2,port n polis head
5,510 evo injecter
6,255 fuel bump
7,gasket (double)
1, use sr20 turbo (come 4000rpm)?-i reco using IHI VF43 from scooby, less lag.
2,port n polis head-if budget allow, just do it.
3,store piston n rod-stock rod won't last, get b18b 1.
4,ecu 0bd0 (what is the best ecu to use) stand alond?-get a hondata s300, put into ur obdo ecu.
5,510 evo injecter- reco using RC.
6,255 fuel bump-great choice & its a must when aiming for 300 over.
7,gasket (double)-get cometic gasket, watever size & thickness u wan oso can, dun use stock & squeeze 2pcs into 1 head...
just 1 cents..
nissan motor 16v turbo.. what compressor about it turbo
---------- Post added at 04:00 PM ---------- 6 hour anti-bump limit - Previous post was at 12:32 PM ----------
b18b1 rod just plus n play?
b18b rod need to do machining in order to fit in ur block... 16v turbo is from nissan rb20det... currently im using it on my engine now...
---------- Post added at 03:31 PM ---------- 6 hour anti-bump limit - Previous post was at 03:30 PM ----------
b18b rods can take up to 300hp...piston u can change to vitara pistons..
where can i get the g16 vitara pistons. can use original vitara pistons or NIPPON n YCP vitara pistons
---------- Post added at 02:25 PM ---------- 6 hour anti-bump limit - Previous post was at 02:20 PM ----------
bro u car run how bar? and h/power.
His car is on second stage project in progress..
dont need to use original vitara piston.. i got my ycp piston for less than 600 but it is bigger bore.. 75.5 mm... so ur block need to bore bigger abit.... running 0.5 bar but h/p dunno... hahaha
ycp piston u got sell bro? how about ur car? nice to run with 16V rb20 turbo?
This is a ceramic turbo. Extremely light and produce effective at very low cfm. Meaning good spool. But, if u are able to keep urself calm and unaddicted to larger G force, u can use this turbo. If u're planning to boost anything higher than 0.9 bar, the turbine fin will fail due to the pressure n heat at high rotation of the shaft.
A good choice would be TD04L from 4G93T gsr for 1.6L. Good spool n reliable if
maintain well. Good output too...
as speed2horizon said.. 16v rb20 cant boost over 0.9... ... for my single cam.. the boost will come in at 3k rpm ...just the range i wan it.... as for the ycp piston i can get for u ... but i need to contact my friend and ask about the price... if ur really interested in the ycp piston ,, pm me..
