Need all the pros in ZTH for proper exhaust system for my ride.
WhiteLighter82
Hi to all the pros in ZTH, need your help on configuring a good exhaust system for my 4G91 Manual ride.
Thanks for the help in advance.
:biggrin:
Current setting is bullet with 1.7" piping and 2.0" muffler........
any ideas on 4-2-1 or 4-1..???
Some workshop guys say that the 4-2-1 extractor should be bigger then the rest of the piping....
Make any sense..?
some say 4-1 cun for 4g93 but for 4g91 dunno. got guy change 4-2-1 cap ayam change back to standard. no power at top
4-2-1 extractor should be good for you.power comes at early rpm
4-1 for better top end power
4-2-1 for low/mid range power
in short,your peak torque will come in at later parts of the RPM range if you go for 4-1,and the other way round for 4-2-1.
when you are racing/driving fast...you drag your rpm all the way to lets say 7k,then shift rpm drops to maybe around 4k then it starts climbing again...till the next shift...from what i understand,for those who like to drag 4-1 is the best cause you will mostly be using high rpms...
but if your car is more for city driving or street driving ...go for 4-2-1..you'll be using more low to mid range power rather then high...you need to decide what you want or whats best for you.nobody can tell you what you want. :nurse:
from the other extractor thread
Make any sense..?
important key factors of an extractor is the length and also diameter.
from what i have read,bigger diameter shifts the torque to higher rpm's
longer tubes brings the peak torque to lower rpm's.
from that i am assuming,4-2-1 should have a smaller diameter and longer tubes
kekeke...u just copy n paste what u just said....
ya bro...malas wanna type...i did the quote thing but its says my message to short,so i suppose to type another message which means more...wait now i will do an edit.:driver: :rofl:
---------- Post added at 09:13 PM ---------- Previous post was at 09:05 PM ----------
edit already :D
Thanks guys for all the info.....
I wonder what the mileage on a normal proper 4G91 on a wira should be per full tank.........
Any ideas guys............
must same or lower compare to old engine. if more no good to you money :biggrin:
A thread every 60 seconds
