my pickup suck!!!
kennyng
penang
my wira 1.5manual pickup is very suck even i changed to 1.6 clutch kit!!. anyone suggest what's problem for my car?
there are 101 reasons why a turbo cant perform , go to experience mechanic to check up
my suggestion
1. compression test
2. ignition timing checkup
3. vacuum leak test
4. wideband AFR checkup
5. tune if needed
my suggestion
1. compression test
3. vacuum leak test
5. tune if needed
it's not turbo ma.it's 1.5:hmmmm:
my suggestion
1. compression test
3. vacuum leak test
5. tune if needed
can explain more details? maybe i can DIY?
nt tht easy
1. compression test - u dont have compression test tools
2. ignition timing checkup - u dont have timing light
3. vacuum leak test - do u have a compressor to check for leaks
4. wideband AFR checkup - you dont have a wideband sensor to check
clutch not improve your pickup.
it just for ensure no slip during pickup.
change engine lo
engine shaking is bcoz of what?
pls be specifiy...
factors lead to engine shaking can be :
1.engine mounting
2.socket lossen
3.plug cable/spark plug problem
4.pressing clutch timing
5.idling not stable
bla bla bla..
A thread every 60 seconds
