1JZ discussion
marlinished
IS yours Auto or Manual..? I would rather go with manual if i want to transplant the engine.. IMO, don't see any pull for auto 1JZs
take JZX100 chaser model
1jz vvt-i single turbo
mouting is same.
need to change the fan
the halfcut cost roughly about 9-10k depends on the condition
normally come with 5 speed
if you want to put in 6 speed. buy supra 6speed gearbox.
the JPJ parts, if you have $$$ everything also can :P
Hey bro..if u are keeping the car for good...then transplant will be ok.
But if u intend to sell the car in the future...then you will find problems..especially the value of yr car.
Think carefully...
Sorry for the misleading questions, I don't own a Altezza but I am considering getting one then convert it to 1JZ in the future or I will get an Evo5/6. Any comments?
buy altezza leh..and get 6cylinder inside.
evo cannot put in 6cylinder.hehehe..
i dont owned an altezza however my ride is wit a mildly modded 1jz gte manual. IMHO i tried the auto before which is around the same setup as mine and i find out it had launch better on a head to head drag.my manual with a big single had trouble getting off the line with no boost. rev up and will encounter wheel spining as getting off the line needs torque/boost and not revs. however the auto works great with one foot on the brake and 1 foot on the acc pedal. boost was built up to 0.3bar when coming off the line and it was feeling like instant respond for the car to jump off when the acc pedal was floored
is300 2jz non turbo. still the same. when you get non turbo 2jz. you will thinking to put in turbo. but yet . the cost bolt on turbo and need to change the internal is same as putting 2jz-gte inside.hehehe.
so good transplant in malaysia is 1jz-gte vvt-i ...
manual is better since we can drift easily compared to auto :p
further 2-jzge comes with 215 ponies only
A thread every 60 seconds
