advanti original taiwan or auto opti thailand?which one the better rim?
Mitevo7
1,456
179
23lbs is normal cast type weight for 18' so still heavy, same like original Toyota 18' rims. Konig Hypergram only weighs around 18+lbs for 18'.
I am not sure about that, but my original Lancer GT rims are fxxking heavy compared to this Sparco. Wonder how heavy as the original rims.
Actually I doubt the Sparco is as heavy as 23lbs if it's much lighter than the stock Lancer 18'. I suspect it's closer to 20lbs and the Lancer stock rims should be around 23-24lbs.
lsm1991
1,469
185
What's wrong with your Advan rims? Stock Evo 7 rims for 1k is already quite cheap these days.
nothing, i just wanted the originals.. i thought can simpan je, just cause i want em....
  • Haha
Reactions: ixeo
ixeo
4,788
3,080
KL, Malaysia
if you’re happy and you know it hog some rims
If you’re happy and you know it hog some rims
Put all 4 pieces on the floor with some rubber pads from Mr.DIY. Get a piece of laminated glass with about 5mm thickness minimum, put rubber pads between rims & floor as well as rims & glass. Viola you’ve got the perfect coffee table.
You can ask other people, can you race your coffee table?
Are Evo kakis like that......hahhahhahahahhaa
I've sold many of my unused stuff la, turbo, manifolds, exhausts, intake, rims and tires etc2. Only left things I plan to use or nobody wants already. Need money to partially cover for other parts I still want.
Mitevo7
1,456
179
Well i got the weight info from Sparco's website. In real life when i lifted it, it's really which can i use both to do laterial raise easily. The original rims on the other hand, i can't even lift it with one hand easily. Have to jerk abit to lift it up.
Hi all zth member,
Would need all of your kind assistance give a look to my friend satria [ convert to Gti ] , just lost his car on 7 March 09 , time around 5pm - 11pm at Tmn Shamelin Perkasa .
Number Plate: - NAR 9413
Please drop me a sms or call if you notice a satria gti look like below:-
Number - 0126450339 - Isaac
- No front grill cause previously had get stolen
- The original satria 1.3 antenna ( on top of the front door )
- No any sticker
- Colour is skyblue...
