If you are just going for a dohc NA, i seriously doubt there will be much issues.
If going for stock GSR turbo unit, Sweelt's unit has been running trouble free thus far.
i'm not planning to do a dohc swap. might bot my single cam but still no budget. somehow, MMC automatics are damn sensitive when it comes to all the sensors and shit. example: TPS reading lari just slightly, it affects the gear shift points and idling. i don't think you'll get issues like this with a manual.
The interior of the car.
Didn't do much juz swap the old roon light to led & mid aircond vent only. Beside that all are original from the previous owner. Some people keep asking me the carpet where did I bought. I also don't know. Hahahahaha
i kena with my mt gsr. Hot start idle like shit. No matter how precise i adjust isc, tps.
After drive for couple of minutes it back to normal.
As long not involve engine lifting, i will troubleshoot myself.
eh yours auto too? hot start if need to crank twice usually is the water temp sensor. rough idling confirm it's stepper motor. dohc one easy to fix. got a lot of tutorial on how to clean and fix it. mine wonky here and there coz using different throttle body (6A11 TB) and i got emanage. intermittent check engine light coz of emanage so no point checking error codes.
good luck finding one. those auto putra a bit hard to get here as well. got running cars on the road la but those also very very rare. ahahaha
Yup, definitely rare to see putra on the road. I can see 5 ranger raptor a day but didn't saw any putra on the road hahahahahha
Mine manual, ya kinda related to temp sensor + many possobilities as i google.
Going to get temp sensor replace. See how.
Been poison by u guys. Now I surveying 4g91 & 92 dohc.
Damn poison woiiiiiiii.Hahahahahaha
i also kena...
nah... here more for you... just upgraded my exhaust to full stainless steel with 4-2-1 + bullet + SE muffler...
The one with the mivec?
without the mivec is good enough. mivec is expensive. later on u can just buy a mivec head with the wiring set and swap with your current head. non mivec 4g92 makes more or about the same power as a 4g93. but 4g92 dohc non mivec also a bit hard to find compare to 4g93.
also, the jdm 4g92 sohc makes about the same power as a 4g93 sohc. export model (australian halfcut) 4g92 is lower power but with a bit of minor head mods u can get more power than a stock 4g93 sohc. the only difference between a 4g92 and 4g93 is the 93 have a longer stroke.
Ok,noted.
The one I am quite interested is this. 4g92 Dohc is 1.6 right?
I think Mitsu all like that or just the engine are too old. Mine morning idle, hot idling, after run very hot idle all different speed one.....lol
