My wife's forester don't have as with newer cars, just the blue and red light....lolDo you have a water temp meter? Maybe would be good to have one
Will try out water temp using OBD2 with phone app, done by some already.....
Nah, no point uprating the PSI. It just means it's holding in more heat - which is what you don't really want.
time for an upgrade of fans! SPAL!
yes very2 clogged radiator from the looks of it
Not too sure about your car specifically, but generally Mitsubishi have a 2-wire temp sensor for the ecu, and the sensor for the meter is actualy a seperate 1-wire sensor, and the gauge is calibrated in such a way that it will show 'normal' over a wide range of temperatures, and will only shoot to H suddenly when it passes a certain temperature, and because the sensor is only 1 wire, the accuracy of the gauge also depends on the chassis and engine grounding. So basically, the stock temp gauge is generally a decent enough indication for overheat, but if you want to be really sure, it is best to install a seperate temperature gauge. Also usually the stock temp sensor detects the water temp at post radiator entering the engine, and not the temp of the water exiting the engine entering the radiator. If you install your own gauge, it will be on the top hose which means you will be reading the higher temperatures of the water exiting the engine entering the radiator.
But then again, looks like you had found your culprit, so just change the radiator and see how la, but if you still experience the same issue again, check your obd water temp see if it tallies up with the gauge reading.
that was an interestingly "easy" fix. What radiator did you opt for?
Usually Synergy can custom build your radiator, probably since yours neither this nor that, so modify existing one......
Nice.. it's great we actually have a confirmed resolved issue shared by the TS. haha! Most just disappear after they post their questions
Can transplant 1j must be rich ...You think i print bank notes ah ??
-Ken-
That and for sure the money printing machine u got in your store...hahah.Can do it cheaply if you know your ways around, i studied the process of it for 3 whole years before deciding to do it. So you won't waste too much unnecessary budget to get things right.
Thanks,
Ken
Make me remember during my banking time..whenever we talk about spending money which we dont have on cars, the sentence 'kejap, aku amek duit lebih kat bawah (the strongroom downstairs), rim nk tuka?, body nak cat?, aku bleh standby lebih' will comes out which will end the conversation abruptly.
Similar threads | |
